All clients showing up in "Network Overview"
Used to show all devices using Pi-hole.
Pi-hole Version v4.3.5
Web Interface Version v4.3.3
FTL Version v4.3.1
Table empty.
No items listed
FTL Version v4.3.1
Table empty.
No items listed
There seems to be some file issues. Can you paste the output from
sudo ls -lach /etc/pihole
please?
pi@PiHole:~ $ sudo ls -lach /etc/pihole
totalt 13M
drwxr-xr-x 2 pihole pihole 4,0K feb 25 19:45 .
drwxr-xr-x 90 root root 4,0K feb 25 14:58 ..
-rw-r--r-- 1 root root 313 feb 25 14:49 adlists.list
-rw-r--r-- 1 root root 313 feb 25 14:49 adlists.list.old
lrwxrwxrwx 1 root root 25 feb 25 14:52 auditlog.list -> /etc/pihole/auditlog.list
lrwxrwxrwx 1 root root 22 feb 25 14:52 black.list -> /etc/pihole/black.list
lrwxrwxrwx 1 root root 25 feb 25 14:52 blacklist.txt -> /etc/pihole/blacklist.txt
-rw-r--r-- 1 pihole pihole 871 feb 26 07:48 dhcp.leases
-rw-r--r-- 1 root root 596 feb 25 14:49 dns-servers.conf
-rw-r--r-- 1 root root 20 feb 25 16:24 GitHubVersions
-rw-r--r-- 1 root root 2,8M feb 25 16:23 gravity.list
-rw-r--r-- 1 root root 1 feb 25 15:30 gravity.list.bak
-rw-r--r-- 1 root root 1,2K feb 25 14:49 install.log
lrwxrwxrwx 1 root root 20 feb 25 14:52 lan.list -> /etc/pihole/lan.list
-rw------- 1 root root 1,6M feb 25 16:23 list.0.raw.githubusercontent.com.domains
-rw------- 1 root root 581K feb 25 14:49 list.1.mirror1.malwaredomains.com.domains
-rw------- 1 root root 624K feb 25 14:49 list.2.sysctl.org.domains
-rw------- 1 root root 613 feb 25 14:49 list.3.s3.amazonaws.com.domains
-rw------- 1 root root 43K feb 25 14:49 list.4.s3.amazonaws.com.domains
-rw------- 1 root root 1,7M feb 25 14:49 list.5.hosts-file.net.domains
-rw-r--r-- 1 root root 2,8M feb 25 16:23 list.preEventHorizon
-rw-r--r-- 1 root root 20 feb 26 08:20 localbranches
-rw-r--r-- 1 root root 43 feb 25 16:23 local.list
-rw-r--r-- 1 root root 43 feb 26 08:20 localversions
-rw-r--r-- 1 root root 234 feb 25 14:49 logrotate
-rw-r--r-- 1 root root 2,3M feb 25 14:49 macvendor.db
-rw-rw-r-- 1 pihole root 15 feb 25 14:49 pihole-FTL.conf
-rw-r--r-- 1 pihole pihole 44K feb 25 19:45 pihole-FTL.db
-rwxrwxrwx 1 root root 3,9K feb 26 08:13 regex.list
-rw-rw-r-- 1 pihole www-data 150 feb 25 16:18 regex.list.bak
-rw-r--r-- 1 root root 579 feb 25 19:44 setupVars.conf
lrwxrwxrwx 1 root root 30 feb 25 14:52 setupVars.conf.bak -> /etc/pihole/setupVars.conf.bak
lrwxrwxrwx 1 root root 37 feb 25 14:52 setupVars.conf.update.bak -> /etc/pihole/setupVars.conf.update.bak
lrwxrwxrwx 1 root root 25 feb 25 14:52 whitelist.bak -> /etc/pihole/whitelist.bak
lrwxrwxrwx 1 root root 25 feb 25 14:52 whitelist.txt -> /etc/pihole/whitelist.txt
pi@PiHole:~ $
How do you have symbolic links for files back on to themselves?
Sorry, I gave no idea of what that even means...
AFAIK I haven't created any of those.
Okay, perhaps another developer can help, or someone from our support team. My only suggestion for the situation would be to get a new Raspbian image and start everything from scratch.
Looks interesting that some files link to themselves I would recommend a restart too, who knows what else is crooked.
Just for my own personal curiosity. Can you show the output from sudo head -n20 /etc/pihole/regex.list
? That file is marked executable and it's kind of large, just wondering if there's something in there that's questionable.
regex.list contains about 190 rows.
I'm in progress of reinstalling on a new sd-card. Old one was really old anyway...
