The issue I am facing:
Network Overview does not show up "Unknown error occurred while loading data"
Details about my system:
Ubuntu 20.04.2 LTS (arm64) on a Raspberry Pi 4B with 2 GB of RAM
Apache2 instead of lighttpd
What I have already tried
Re-Install of SQLite3 and php-sqlite via:
sudo apt remove --purge sqlite3 php-sqlite
sudo apt autoremove --purge -y
sudo apt install sqlite3 php-sqlite
jfb
2
Delete your long term database and restart FTL.
How?
When I click on "Flush Network Table" in the settings section on the pi-hole web interface I get the following message:
e[K [✗] Failed to truncate network_addresses table
Database location: /etc/pihole/pihole-FTL.db
Output: Error: database disk image is malformed
sudo service pihole-FTL stop
sudo rm /etc/pihole/pihole-FTL.db
sudo service pihole-FTL start
Thank You, jfb and yubiuser! Now the Network-Table shows up again!
system
Closed
6
