hi i been trying to block the in-video ads that come up every 15 minutes on www.locast.org
i installed adam:one assistant, and block every domain that comes up when im watching a video on the website, but even after that i still get the in video ads on this website when im streaming channels
any help or recommendation will be highly appreciate.
It is likely that the ads are being served from the same domains as the video. What domains are you seeing when you play a video from that site (a few examples)?
sorry im very new to this i dont know how to get that information im using the gui to connect to pihole from a windows pc. (pihole -t) is that a terminal command you want me to use directly on the raspberry pi? or can i get that information from the gui
From the GUI > tools > tail pihole log ; this accomplishes the same as the terminal command pihole -t, but without the color coding for blocked domains.
Mar 24 22:01:44 dnsmasq[866]: query[A] f.vimeocdn.com from 192.168.5.1
Mar 24 22:01:44 dnsmasq[866]: forwarded f.vimeocdn.com to 8.8.4.4
Mar 24 22:01:44 dnsmasq[866]: query[A] fresnel.vimeocdn.com from 192.168.5.1
Mar 24 22:01:44 dnsmasq[866]: forwarded fresnel.vimeocdn.com to 8.8.4.4
Mar 24 22:01:44 dnsmasq[866]: reply fresnel.vimeocdn.com is <CNAME>
Mar 24 22:01:44 dnsmasq[866]: reply vimeo-video.map.fastly.net is 151.101.250.109
Mar 24 22:01:44 dnsmasq[866]: reply f.vimeocdn.com is <CNAME>
Mar 24 22:01:44 dnsmasq[866]: reply vimeo-video.map.fastly.net is 199.232.38.109
Mar 24 22:01:46 dnsmasq[866]: query[A] fans.tmsimg.com from 192.168.5.1
Mar 24 22:01:46 dnsmasq[866]: forwarded fans.tmsimg.com to 8.8.4.4
Mar 24 22:01:46 dnsmasq[866]: reply fans.tmsimg.com is <CNAME>
Mar 24 22:01:46 dnsmasq[866]: reply d161k4gc3fyfos.cloudfront.net is 204.246.169.131
Mar 24 22:01:46 dnsmasq[866]: query[A] api.locastnet.org from 192.168.5.1
Mar 24 22:01:46 dnsmasq[866]: forwarded api.locastnet.org to 8.8.4.4
Mar 24 22:01:46 dnsmasq[866]: reply api.locastnet.org is <CNAME>
Mar 24 22:01:46 dnsmasq[866]: reply api-lb-1922556437.us-east-2.elb.amazonaws.com is 3.17.127.64
Mar 24 22:01:46 dnsmasq[866]: reply api-lb-1922556437.us-east-2.elb.amazonaws.com is 18.191.113.37
Mar 24 22:01:47 dnsmasq[866]: query[A] cdn.locastnet.org from 192.168.5.1
Mar 24 22:01:47 dnsmasq[866]: forwarded cdn.locastnet.org to 8.8.4.4
Mar 24 22:01:47 dnsmasq[866]: reply cdn.locastnet.org is <CNAME>
Mar 24 22:01:47 dnsmasq[866]: reply cdn.wpc.9891c.alphacdn.net is <CNAME>
Mar 24 22:01:47 dnsmasq[866]: reply s13.ne1.wpc.mucdn.net is 152.195.12.204
Mar 24 22:01:56 dnsmasq[866]: query[A] www.baidu.com from 192.168.5.1
Mar 24 22:01:56 dnsmasq[866]: forwarded www.baidu.com to 8.8.4.4
Mar 24 22:01:56 dnsmasq[866]: reply www.baidu.com is <CNAME>
Mar 24 22:01:56 dnsmasq[866]: reply www.a.shifen.com is <CNAME>
Mar 24 22:01:56 dnsmasq[866]: reply www.wshifen.com is 104.193.88.123
Mar 24 22:01:56 dnsmasq[866]: reply www.wshifen.com is 104.193.88.77
Mar 24 22:02:11 dnsmasq[866]: query[A] www.baidu.com from 192.168.5.1
Mar 24 22:02:11 dnsmasq[866]: forwarded www.baidu.com to 8.8.4.4
Mar 24 22:02:11 dnsmasq[866]: reply www.baidu.com is <CNAME>
Mar 24 22:02:11 dnsmasq[866]: reply www.a.shifen.com is <CNAME>
Mar 24 22:02:11 dnsmasq[866]: reply www.wshifen.com is 104.193.88.123
Mar 24 22:02:11 dnsmasq[866]: reply www.wshifen.com is 104.193.88.77
Mar 24 22:02:27 dnsmasq[866]: query[A] www.baidu.com from 192.168.5.1
Mar 24 22:02:27 dnsmasq[866]: forwarded www.baidu.com to 8.8.4.4
Mar 24 22:02:27 dnsmasq[866]: reply www.baidu.com is <CNAME>
Mar 24 22:02:27 dnsmasq[866]: reply www.a.shifen.com is <CNAME>
Mar 24 22:02:27 dnsmasq[866]: reply www.wshifen.com is 104.193.88.123
Mar 24 22:02:27 dnsmasq[866]: reply www.wshifen.com is 104.193.88.77
Mar 24 22:02:42 dnsmasq[866]: query[A] www.baidu.com from 192.168.5.1
Mar 24 22:02:42 dnsmasq[866]: forwarded www.baidu.com to 8.8.4.4
Mar 24 22:02:42 dnsmasq[866]: reply www.baidu.com is <CNAME>
Mar 24 22:02:42 dnsmasq[866]: reply www.a.shifen.com is <CNAME>
Mar 24 22:02:42 dnsmasq[866]: reply www.wshifen.com is 104.193.88.77
Mar 24 22:02:42 dnsmasq[866]: reply www.wshifen.com is 104.193.88.123
i did that flush the DNS added the cdn.localcast.com to the block list but still the in video ad persist maybe someone with more knowledge can go to the website and see if is possible to block at all www.locast.org
