Let's start with a single client and get that working on Pi-Hole.
I assume you have tried to set the DNS settings on your router and that has not worked.
What clients do you have - do you have a PC?
Yes I do have a PC with Windows. I have set my router as other provider to turn off the DHCP from my provider. After that I enabled the DHCP server on Raspberry pi hole and chose the cloud DNS as upload DNS server.
I don't know what am I doing wrong. It's really frustrating. Should I post the screen shots of my pi hole DNS settings here for correction?
What is the output of ipconfig /all
from the PC terminal?
Hi, can you pls post the DNS server settings on pihole for me pls. I don't know what I am doing wrong only some ads are getting blocked not all.
Here is the screenshot of my settings.
Correct me what u am doing wrong. Thanks
This isn't the information we need to help you solve this problem. We need this:
It's 01:15 in the midnight. I am really very tired from work and typing from bed. Can I give you the output of this tomorrow? May be in 7 hrs from now?
Thanks
Hi, here is the Output of ipconfig /all from my computer
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2016 Microsoft Corporation. All rights reserved. Re-Designed By M
uhammad SadeemC:\Users\Manu>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Manu-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : speedport.ipEthernet adapter Local Area Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : TAP-Windows Adapter V9
Physical Address. . . . . . . . . : 00-FF-CA-49-0B-DD
Autoconfiguration Enabled . . . . : YesEthernet adapter Local Area Connection:
Connection-specific DNS Suffix . : speedport.ip
Description . . . . . . . . . . . : Realtek RTL8102E/RTL8103E Family PCI-E Fa
st Ethernet NIC (NDIS 6.20)
Physical Address. . . . . . . . . : 00-23-18-BC-13-4A
Autoconfiguration Enabled . . . . : YesWireless LAN adapter Wireless Network Connection:
Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network AdapterPhysical Address. . . . . . . . . : 00-24-D2-D4-81-55
IPv6 Address. . . . . . . . . . . : 2003:d6:7f1b:3d44:c30:dcbf:94ec:f0f1(Pref
erred)
Temporary IPv6 Address. . . . . . : 2003:d6:7f1b:3d44:b5f7:f5ed:fb0e:9fe8(Pre
ferred)
Link-local IPv6 Address . . . . . : fe80::c30:dcbf:94ec:f0f1%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.2.103(Preferred)
Lease Obtained. . . . . . . . . . : Saturday, July 20, 2019 8:32:22 AM
Lease Expires . . . . . . . . . . : Saturday, August 10, 2019 8:32:21 AM
Default Gateway . . . . . . . . . : fe80::1%11
192.168.2.1
DHCP Server . . . . . . . . . . . : 192.168.2.1
DHCPv6 IAID . . . . . . . . . . . : 184558802
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-23-06-92-3D-00-23-18-BC-13-4ADNS Servers . . . . . . . . . . . : fe80::1%11
192.168.2.1
On the PC, manually map the DNS to the IPv4 address of the Pi, and disable IPv6. This will eliminate IPv6 and the router as potential sources of the problem.
I didn't get you. What exactly do you want me to do? If I disable ipv6 on pc will it disable on pihole ?
What are the DNS settings I should choose in pihole?
Change the DNS settings on the PC to manually point to Pi-Hole. If you do not know how to do it, then do a web search and you will find many videos and instructions.
No.
Don't change anything in Pi-Hole. As noted in two previous replies, this is not a Pi-Hole configuration problem.
But i do see ads on my mobile. Should i also change the DNS settings in my Mobile ?
Do you want Pi-hole to block ads on your mobile?
Get your PC working, then will figure out where the problem lies.
One thing worth mentioning for future reference, I had devices looking for IPv6 DNS which, oddly enough, on my ISP provided router has a different set of DNS config pages. That was annoying.. I noticed it on iOS devices which tend to prefer IPv6 in a big way.
Yes. I thought pi hole blocks adds network wide. Have I misunderstood here?
I still didn't get the logic what you are trying to explain me...
You have to tell the devices to use Pi-hole. It can not intercept and replace.
I think you need to spend some time reading https://docs.pi-hole.net and see how it works, how to install it and how to configure your clients and network to use Pi-hole. Until you understand the basics of how things work then any troubleshooting we do will be of little use.
Yes, IPv6 is a different beast to get working. It's not as easy with IPv4 and a single IP address to manage, instead you have a handful of IPv6 addresses and a completely different scheme for DHCP (or the intended lack of DHCP for the protocol.)
