Monitoring devices connected to Pihole
Hi everyone,
I've just been using Pihole and I find it an interesting software.
I would like to understand is there a section in the dashboard where I can control the devices that connect to the network? At home I use a cool PC and several smartphones. Can I view them individually?
Thank you all
Michele
I believe under clients, you can add IP addresses of the devices and you can see the breakdown accordingly.
I'll try your advice. Thanks so much for the reply!!!!
The clients are visible in the section but only with their mac addresses. I'm having a hard time understanding which devices the addresses refer to. Can you explain to me how to do it?
To find out the IP address or MAC address of a cell phone, go to Network setting / Wi-Fi setting. Click on the icon gear, under network details, you can find both the IP address and MAC address. Write it down and you need to enter it in the client list (in pi-hole settings) with device name, then click Add. Click Save when done.
Every phone setting may look different. Hope fully you will find it.
On a computer, click on the wifi or network icon and click on properties. Look for IP or IPv4 address and MAC or Physical address (MAC).
Your router also would show addresses, but if you do not know which one is which, you will have to go device by device anyway.
I hope this helps.
I found the mac addresses. I inserted them in the clients section and assigned the name (asus_5Ghz_wifi). But on the dashboard I don't see the traffic of the "asus_5Ghz_wifi" client.
Where am I wrong? I restarted pihole to update but still nothing.
I don't understand where I'm wrong.
Thanks a lot
You can use the query log (on Left, 2nd below Dashboard), Use Advance filtering, Click the client name in the client list drop down list or type IP address. These will filter and show you the traffic from that client only.
I did as you suggested but in the query section, the clients are all 172.18.0.1. The pihole runs on Nas Synology, could that be the problem?
docker
driver: bridge
subnet: 172.18.0.0/16
gateway: 172.18.0.1
ipv6: disable
container: pihole
Always thanks for the support.
In your pi-hole, on the left side panel, click “Settings” and then “DNS”. In DNS Settings, right hand top corner click Basic to Expert. Under “Interface Settings” select “Permit all origins”. And run it for a day and see if this makes any difference in your breakdown.
I did as you suggested.
I changed the "Allow only local requests" option to "Permit all origins".
Let's see if anything changes.
Always thank you.
No.
As a filtering DNS server, Pi-hole is accepting DNS requests from your local network.
It would be your router's job to control access to that network, e.g. by authenticating client connections (e.g. its wifi network) or allow only devices with known MAC addresses.
