Hello,
Trying Pihole on LinuxMint 21.1. I was able to install it, but when I try to update it, I get this,
Then it says,
If you are seeing this message after having run pihole -up:
sudo PIHOLE_SKIP_OS_CHECK=true pihole -r
but when I use that command, I get this...
Why does it say FTL is missing when I was able to install pihole and add adlists and it was working fine. This is only when I try to update it.
Any ideas?
