I would like to gift a pihole-pi to my brother. I set it up, and it said - within the installer - that it would set the dhcp'ed ip to the static. No problem so war in my network. But my brother is using an other ip-range 192.168.x.x So wouldn't he run into problems, when he connected the raspi? Or is the dhcp client on the Raspi still running and pihole just fetches a new ip??
What to I have to change? and where? to make it easy for my brother,..
static ip would be set in dhcpd.conf i just nano'd the file on my end and found no entries
EDIT /etc/dhcpcd.conf is where the static would be set. A quick way to check is to look at /etc/network/interfaces and see if the interface is manual which means dhcpcd is in control, or if it’s set to dhcp which would pull a dhcp IP address. If it is set to static then something has made that change and we should revert that before giving ti to your brother
