I have Pi-hole working fine, but may I use the same server for Pi-Alert if I give it enough memory? Will they have a conflict?
Thanks
As long as there are no port conflicts or dnsmasq configuration conflicts, there should be no problem.
Make a backup of your SD card and give the new software a whirl. Worst case, something breaks and you revert back to your original software.
