Recently upgraded my internet which required a separate router. I have Pihole configured on a synology and it keeps restarting. Cable co is useless as they don't understand. Any one here familiar with this issue. TIA
P.S. I changed the server ip to match the synology.
It would help if you posted more information on the configuration of the docker container that you have created on the Synolgoy.
Are you using docker-compose or just CLI - post the command line or compose file
Network type - how did you configure your synolgoy network adapter (static, dhcp, etc)
