Pi-hole to continue to block ads and not block the whole internet after adding unbound.
Pi-hole was blocking ads as expected until I installed and implemented unbound, then I was unable to access the internet. I installed pi-hole from a docker onto an odroid xu4 using openmediavault.
Thanks for the suggestion. I will consider it if no one else responds. Could I install it using Ubuntu 16? I have run that before on the Odroid.
I just figured it was some kind of a wrong setting on my Tomato router, as pihole + unbound works fine when I just set one client alone to the pihole dns resolver.
The problem beforef pi-hole V4 was that it would try to use whatever version of dnsmasq was already installed (V16 ubuntu seemed to be OK, based on what I have read here in other threads). Now, pi-hole maintains and uses it own special version of dnsmasq (If I understand what I have read correctly ).
As far as unbound, sorry my reading hasn't taken me that far yet.
From my experience as a programmer, it's better to get one basic system (pi-hole) to work as promised, and then start adding on more features.
