pi 3b
lost connection to api
systemctl restart pihole-FTL and service pihole-FTL restart
did not work
pi 3b
did not work
Please post the output of
cat /var/log/pihole-FTL.log
After attempting to restart pihole-FTL
, what's the output of:
sudo systemctl status --full --no-pager pihole-FTL.service
Active: activating (start) since Wed 2020-10-28 22:26:31 CET; 2min 58s ago
Cntrl PID: 592 (bash)
Tasks: 1 (limit: 2063)
└─592 bash /etc/init.d/pihole-FTL start
Okt 28 22:26:31 pi systemd[1]: Starting LSB: pihole-FTL daemon...
Okt 28 22:26:31 pi pihole-FTL[448]: Terminated
Okt 28 22:26:31 pi pihole-FTL[592]: Stopped
Okt 28 22:26:32 pi su[613]: (to pihole) root on none
Okt 28 22:26:32 pi su[613]: pam_unix(su:session): session opened for user pihole by (uid=0)
Your log doesn't show any apparent errors or crashes.
But immediately after starting, FTL has to increase it's memory quite fast. Also in your debug log this indicates a lot of queries. Maybe you run out of memory.
-rw------- 1 pihole pihole 294748160 Oct 28 13:02 /dev/shm/FTL-queries
What is the output of
echo ">top-clients >quit" | nc localhost 4711
Also post the output of:
echo ">top-domains >quit" | nc localhost 4711
0 4341498 192.168.1.1 unifi.nix
1 5253 192.168.1.69 mb-k.nix
2 1376 192.168.1.103 bigeasy.nix
3 89 127.0.0.1 localhost
4 35 192.168.1.30
5 4 192.168.1.18
domains_being_blocked 123169
dns_queries_today 4348263
ads_blocked_today 862
ads_percentage_today 0.019824
unique_domains 1158
queries_forwarded 4346963
queries_cached 424
clients_ever_seen 6
unique_clients 6
dns_queries_all_types 4348263
reply_NODATA 21
reply_NXDOMAIN 4
reply_CNAME 302
reply_IP 646
privacy_level 0
status enabled
0 2343643 lb._dns-sd._udp.0.1.168.192.in-addr.arpa
1 1995441 lb._dns-sd._udp.nix
2 312 e17437.dscb.akamaiedge.net
3 310 ping.ubnt.com
4 257 gateway.fe.apple-dns.net
5 195 me.apple-dns.net
6 165 ips1.unifi-ai.com
7 136 xp.itunes-apple.com.akadns.net
8 125 mesu-cdn.origin-apple.com.akadns.net
9 84 pbs.twimg.com
and thx for the help
This is the source of your problem, I believe. A very high number of queries in 24 hours (over 4.3 million), and they appear to be caused by a conditional forwarding loop.
The Unifi controller is making a huge number of DNS Discovery Service requests.
I would start with disabling conditional forwarding and see if this tames the traffic.
big thxs
this was the problem.
now pihole is running without problems
