Every now and then pihole will lose connection to the api. This doesnt seem to happen in any particular pattern and I havent been able to track down why it is doing it. When the connection to the api is down, I dont see anything using port 53 (via the following cmd: sudo lsof -i :53 +c 0 | awk 'FNR==2{ print $1 }'), and if i type pihole restartdns, it will generally restart after a couple mins.
Current version (guessing that the latest error part is because the connection is currently down)
Pi-hole version is v4.3.2 (Latest: ERROR)
AdminLTE version is v4.3.2 (Latest: ERROR)
FTL version is v4.3.1 (Latest: ERROR)
pi@raspberrypi:~ $ service pihole-FTL status
Active: active (exited) since Sun 2020-01-19 17:35:08 EST; 2 days ago
Process: 342 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
Jan 19 17:34:54 raspberrypi systemd[1]: Starting LSB: pihole-FTL daemon...
Jan 19 17:34:55 raspberrypi pihole-FTL[342]: Not running
Jan 19 17:35:06 raspberrypi su[587]: (to pihole) root on none
Jan 19 17:35:06 raspberrypi su[587]: pam_unix(su:session): session opened for user pihole by (uid=0)
Jan 19 17:35:08 raspberrypi pihole-FTL[342]: FTL started!
Jan 19 17:35:08 raspberrypi systemd[1]: Started LSB: pihole-FTL daemon.
on the web interface dashboard I expect to see graphs indicating blocked Adds
I see spinning arrows instead of graphs and “lost connection to api” at the top of the page.
3dxeuglnmc
