Also do you have an /etc/dnsmasq.conf
file and what are the contents of the file if you do have one.
Try sudo /usr/bin/pihole-FTL debug
Contents of dnsmasq.conf:
conf-dir=/etc/dnsmasq.d
[2019-11-08 20:15:06.546 20537] Using log file /var/log/pihole-FTL.log
[2019-11-08 20:15:06.547 20537] ########## FTL started! ##########
[2019-11-08 20:15:06.547 20537] FTL branch: master
[2019-11-08 20:15:06.547 20537] FTL version: v4.3.1
[2019-11-08 20:15:06.547 20537] FTL commit: b60d63f
[2019-11-08 20:15:06.547 20537] FTL date: 2019-05-25 21:37:26 +0200
[2019-11-08 20:15:06.547 20537] FTL user: root
[2019-11-08 20:15:06.547 20537] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-11-08 20:15:06.548 20537] SOCKET_LISTENING: only local
[2019-11-08 20:15:06.548 20537] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2019-11-08 20:15:06.548 20537] MAXDBDAYS: max age for stored queries is 365 days
[2019-11-08 20:15:06.548 20537] RESOLVE_IPV6: Resolve IPv6 addresses
[2019-11-08 20:15:06.548 20537] RESOLVE_IPV4: Resolve IPv4 addresses
[2019-11-08 20:15:06.548 20537] DBINTERVAL: saving to DB file every minute
[2019-11-08 20:15:06.549 20537] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-11-08 20:15:06.549 20537] MAXLOGAGE: Importing up to 24.0 hours of log data
[2019-11-08 20:15:06.549 20537] PRIVACYLEVEL: Set to 0
[2019-11-08 20:15:06.549 20537] IGNORE_LOCALHOST: Show queries from localhost
[2019-11-08 20:15:06.549 20537] BLOCKINGMODE: Null IPs for blocked domains
[2019-11-08 20:15:06.549 20537] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2019-11-08 20:15:06.549 20537] DBIMPORT: Importing history from database
[2019-11-08 20:15:06.550 20537] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-11-08 20:15:06.550 20537] PORTFILE: Using /var/run/pihole-FTL.port
[2019-11-08 20:15:06.550 20537] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-11-08 20:15:06.550 20537] WHITELISTFILE: Using /etc/pihole/whitelist.txt
[2019-11-08 20:15:06.550 20537] BLACKLISTFILE: Using /etc/pihole/black.list
[2019-11-08 20:15:06.550 20537] GRAVITYFILE: Using /etc/pihole/gravity.list
[2019-11-08 20:15:06.550 20537] REGEXLISTFILE: Using /etc/pihole/regex.list
[2019-11-08 20:15:06.551 20537] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2019-11-08 20:15:06.551 20537] AUDITLISTFILE: Using /etc/pihole/auditlog.list
[2019-11-08 20:15:06.551 20537] MACVENDORDB: Using /etc/pihole/macvendor.db
[2019-11-08 20:15:06.551 20537] PARSE_ARP_CACHE: Active
[2019-11-08 20:15:06.551 20537] Finished config file parsing
[2019-11-08 20:15:06.553 20537] WARNING: Starting pihole-FTL as user root is not recommended
That looks good, the binary is working correctly.
Next try su -s /bin/sh -c "/usr/bin/pihole-FTL" pihole
You may need a sudo
in front of that if you are not currently the root user.
Ran the command, no information returned. I indeed had to use sudo
as well.
Can you get us a copy of your /var/log/pihole-FTL.log
file? cat /var/log/pihole-FTL.log | pihole tricorder
will do that and give you a URL to link to.
You bet, here you go:
https://tricorder.pi-hole.net/9tc4hgpg3s
Thanks, that does show a crash of pihole-FTL but after that there are a few successful starts of the daemon. You will need to remove any FTL
files in /var/run/shm/
. After that try starting pihole-FTL
again.
That did it! Thank you for taking the time to look through this.
Hopefully that is the last time I see any of this. Will bookmark this just in case I see this crop up yet again.
If it happens again then check /var/log/pihole-FTL.log
to see if there was a crash or if things were shut down. I see the below block from your log that shows FTL was shutdown intentionally. That could either be from you shutting things down or it is possible that something else is calling for the process to be terminated.
[2019-11-08 16:38:53.473 26022] Resizing "/FTL-strings" from 40960 to 45056
[2019-11-08 17:41:05.722 26022] Shutting down...
[2019-11-08 17:41:05.922 26022] Finished final database update [2019-11-08 17:41:05.926 26022] ########## FTL terminated after 145954784.0 ms! ##########
