https://tricorder.pi-hole.net/tvlu3abmfy !
I've been having a terrible time. Was experimenting with the Conditional Forwarding settings and they didn't work, so I tried to change it back (Cond. Forwarding disabled) and Pihole is confused. The Admin page says DNS and FTL is not running, and Lost Connection to API.
I have run pihole -r to both repair and configure, and it didn't help.
Status of services:
dnsmasq - removed via apt-get
pihole-FTL: pihole-FTL[2965]: Not running
I even tried the "pihole checkout ftl master" then "pihole -r" and it didn't help. Also restarted the pihole-FTL service multiple times with no help.
jfb
April 12, 2019, 11:30pm
2
Your debug log confirms that pihole-FTL is not running. Let's find out why.
What are the outputs of the following:
sudo netstat -nltup | grep 'Proto\|:53 \|:67 \|:80 \|:471'
sudo grep FTL /var/log/pihole-FTL.log
`sudo netstat -nltup | grep 'Proto\|:53 \|:67 \|:80 \|:471'`
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 2845/lighttpd
tcp6 0 0 :::80 :::* LISTEN 2845/lighttpd
**●** pihole-FTL.service - LSB: pihole-FTL daemon
Loaded: loaded (/etc/init.d/pihole-FTL; generated; vendor preset: enabled)
Active: **active (exited)** since Fri 2019-04-12 18:03:16 CDT; 31min ago
Process: 2959 ExecStop=/etc/init.d/pihole-FTL stop (code=exited, status=0/SUCCESS)
Process: 2965 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
[2019-04-12 17:17:06.186 3158] ########## FTL started! ##########
[2019-04-12 17:17:06.186 3158] FTL branch: master
[2019-04-12 17:17:06.186 3158] FTL commit: aae487e
[2019-04-12 17:17:06.186 3158] FTL date: 2019-02-25 17:18:14 -0800
[2019-04-12 17:17:06.186 3158] FTL user: pihole
[2019-04-12 17:17:06.186 3158] FTL version: v4.2.3
[2019-04-12 17:17:06.186 3158] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-04-12 17:17:06.186 3158] Using log file /var/log/pihole-FTL.log
[2019-04-12 17:17:06.187 3158] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-04-12 17:17:06.187 3158] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-04-12 17:17:06.187 3158] PORTFILE: Using /var/run/pihole-FTL.port
[2019-04-12 17:17:06.187 3158] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-04-12 17:17:06.197 3158] Resizing "/FTL-strings" from 4096 to 8192
[2019-04-12 17:17:06.201 3158] Resizing "/FTL-strings" from 8192 to 12288
[2019-04-12 17:17:06.204 3158] Resizing "/FTL-strings" from 12288 to 16384
[2019-04-12 17:17:06.211 3158] Resizing "/FTL-strings" from 16384 to 20480
[2019-04-12 17:17:06.222 3158] Resizing "/FTL-strings" from 20480 to 24576
[2019-04-12 17:17:06.239 3158] Resizing "/FTL-strings" from 24576 to 28672
[2019-04-12 17:17:06.241 3158] Resizing "/FTL-queries" from 229376 to 458752
[2019-04-12 17:17:06.264 3158] Resizing "/FTL-strings" from 28672 to 32768
[2019-04-12 17:17:06.293 3158] Resizing "/FTL-strings" from 32768 to 36864
[2019-04-12 17:17:06.334 3158] Resizing "/FTL-strings" from 36864 to 40960
[2019-04-12 17:17:06.336 3158] Resizing "/FTL-queries" from 458752 to 688128
[2019-04-12 17:17:06.427 3158] Resizing "/FTL-queries" from 688128 to 917504
[2019-04-12 17:17:06.467 3158] Resizing "/FTL-strings" from 40960 to 45056
[2019-04-12 17:17:06.516 3158] Resizing "/FTL-queries" from 917504 to 1146880
[2019-04-12 17:17:06.591 3158] Resizing "/FTL-strings" from 45056 to 49152
[2019-04-12 17:17:06.600 3158] Resizing "/FTL-queries" from 1146880 to 1376256
[2019-04-12 17:17:06.641 3158] Resizing "/FTL-strings" from 49152 to 53248
[2019-04-12 17:17:06.694 3158] Resizing "/FTL-strings" from 53248 to 57344
[2019-04-12 17:17:06.718 3158] Resizing "/FTL-queries" from 1376256 to 1605632
[2019-04-12 17:17:06.752 3158] Resizing "/FTL-strings" from 57344 to 61440
[2019-04-12 17:17:06.852 3158] Resizing "/FTL-queries" from 1605632 to 1835008
[2019-04-12 17:17:06.885 3158] Resizing "/FTL-strings" from 61440 to 65536
[2019-04-12 17:17:06.989 3158] Resizing "/FTL-queries" from 1835008 to 2064384
[2019-04-12 17:17:07.028 3158] Resizing "/FTL-strings" from 65536 to 69632
[2019-04-12 17:17:07.123 3158] Resizing "/FTL-queries" from 2064384 to 2293760
[2019-04-12 17:17:07.128 3158] Resizing "/FTL-strings" from 69632 to 73728
[2019-04-12 17:19:01.145 3602] ########## FTL started! ##########
[2019-04-12 17:19:01.145 3602] FTL branch: master
[2019-04-12 17:19:01.145 3602] FTL commit: aae487e
[2019-04-12 17:19:01.145 3602] FTL date: 2019-02-25 17:18:14 -0800
[2019-04-12 17:19:01.145 3602] FTL version: v4.2.3
[2019-04-12 17:19:01.145 3602] Using log file /var/log/pihole-FTL.log
[2019-04-12 17:19:01.146 3602] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-04-12 17:19:01.146 3602] FTL user: pihole
[2019-04-12 17:19:01.146 3602] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-04-12 17:19:01.147 3602] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-04-12 17:19:01.147 3602] PORTFILE: Using /var/run/pihole-FTL.port
[2019-04-12 17:19:01.147 3602] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-04-12 17:19:01.157 3602] Resizing "/FTL-strings" from 4096 to 8192
[2019-04-12 17:19:01.159 3602] Resizing "/FTL-strings" from 8192 to 12288
[2019-04-12 17:19:01.163 3602] Resizing "/FTL-strings" from 12288 to 16384
[2019-04-12 17:19:01.169 3602] Resizing "/FTL-strings" from 16384 to 20480
[2019-04-12 17:19:01.181 3602] Resizing "/FTL-strings" from 20480 to 24576
[2019-04-12 17:19:01.198 3602] Resizing "/FTL-strings" from 24576 to 28672
[2019-04-12 17:19:01.201 3602] Resizing "/FTL-queries" from 229376 to 458752
[2019-04-12 17:19:01.219 3602] Resizing "/FTL-strings" from 28672 to 32768
[2019-04-12 17:19:01.245 3602] Resizing "/FTL-strings" from 32768 to 36864
[2019-04-12 17:19:01.284 3602] Resizing "/FTL-strings" from 36864 to 40960
[2019-04-12 17:19:01.287 3602] Resizing "/FTL-queries" from 458752 to 688128
[2019-04-12 17:19:01.369 3602] Resizing "/FTL-queries" from 688128 to 917504
[2019-04-12 17:19:01.426 3602] Resizing "/FTL-strings" from 40960 to 45056
[2019-04-12 17:19:01.447 3602] Resizing "/FTL-queries" from 917504 to 1146880
[2019-04-12 17:19:01.523 3602] Resizing "/FTL-strings" from 45056 to 49152
[2019-04-12 17:19:01.535 3602] Resizing "/FTL-queries" from 1146880 to 1376256
[2019-04-12 17:19:01.574 3602] Resizing "/FTL-strings" from 49152 to 53248
[2019-04-12 17:19:01.625 3602] Resizing "/FTL-strings" from 53248 to 57344
[2019-04-12 17:19:01.653 3602] Resizing "/FTL-queries" from 1376256 to 1605632
[2019-04-12 17:19:01.685 3602] Resizing "/FTL-strings" from 57344 to 61440
[2019-04-12 17:19:01.783 3602] Resizing "/FTL-queries" from 1605632 to 1835008
[2019-04-12 17:19:01.811 3602] Resizing "/FTL-strings" from 61440 to 65536
[2019-04-12 17:19:01.911 3602] Resizing "/FTL-queries" from 1835008 to 2064384
[2019-04-12 17:19:01.951 3602] Resizing "/FTL-strings" from 65536 to 69632
[2019-04-12 17:19:02.042 3602] Resizing "/FTL-queries" from 2064384 to 2293760
[2019-04-12 17:19:02.047 3602] Resizing "/FTL-strings" from 69632 to 73728
[2019-04-12 17:20:35.007 920] Using log file /var/log/pihole-FTL.log
[2019-04-12 17:20:35.008 920] ########## FTL started! ##########
[2019-04-12 17:20:35.008 920] FTL branch: master
[2019-04-12 17:20:35.008 920] FTL version: v4.2.3
[2019-04-12 17:20:35.009 920] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-04-12 17:20:35.009 920] FTL commit: aae487e
[2019-04-12 17:20:35.009 920] FTL date: 2019-02-25 17:18:14 -0800
[2019-04-12 17:20:35.009 920] FTL user: pihole
[2019-04-12 17:20:35.009 920] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-04-12 17:20:35.010 920] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-04-12 17:20:35.010 920] PORTFILE: Using /var/run/pihole-FTL.port
[2019-04-12 17:20:35.010 920] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-04-12 17:20:35.069 920] Resizing "/FTL-strings" from 4096 to 8192
[2019-04-12 17:20:35.071 920] Resizing "/FTL-strings" from 8192 to 12288
[2019-04-12 17:20:35.076 920] Resizing "/FTL-strings" from 12288 to 16384
[2019-04-12 17:20:35.083 920] Resizing "/FTL-strings" from 16384 to 20480
[2019-04-12 17:20:35.102 920] Resizing "/FTL-strings" from 20480 to 24576
[2019-04-12 17:20:35.121 920] Resizing "/FTL-strings" from 24576 to 28672
[2019-04-12 17:20:35.127 920] Resizing "/FTL-queries" from 229376 to 458752
[2019-04-12 17:20:35.146 920] Resizing "/FTL-strings" from 28672 to 32768
[2019-04-12 17:20:35.173 920] Resizing "/FTL-strings" from 32768 to 36864
[2019-04-12 17:20:35.213 920] Resizing "/FTL-strings" from 36864 to 40960
[2019-04-12 17:20:35.219 920] Resizing "/FTL-queries" from 458752 to 688128
[2019-04-12 17:20:35.305 920] Resizing "/FTL-queries" from 688128 to 917504
[2019-04-12 17:20:35.375 920] Resizing "/FTL-strings" from 40960 to 45056
[2019-04-12 17:20:35.391 920] Resizing "/FTL-queries" from 917504 to 1146880
[2019-04-12 17:20:35.472 920] Resizing "/FTL-strings" from 45056 to 49152
[2019-04-12 17:20:35.486 920] Resizing "/FTL-queries" from 1146880 to 1376256
[2019-04-12 17:20:35.526 920] Resizing "/FTL-strings" from 49152 to 53248
[2019-04-12 17:20:35.574 920] Resizing "/FTL-strings" from 53248 to 57344
[2019-04-12 17:20:35.604 920] Resizing "/FTL-queries" from 1376256 to 1605632
[2019-04-12 17:20:35.635 920] Resizing "/FTL-strings" from 57344 to 61440
[2019-04-12 17:20:35.739 920] Resizing "/FTL-queries" from 1605632 to 1835008
[2019-04-12 17:20:35.765 920] Resizing "/FTL-strings" from 61440 to 65536
[2019-04-12 17:20:35.868 920] Resizing "/FTL-queries" from 1835008 to 2064384
[2019-04-12 17:20:35.909 920] Resizing "/FTL-strings" from 65536 to 69632
[2019-04-12 17:20:35.998 920] Resizing "/FTL-queries" from 2064384 to 2293760
[2019-04-12 17:20:36.003 920] Resizing "/FTL-strings" from 69632 to 73728
[2019-04-12 17:27:41.333 1135] ########## FTL started! ##########
[2019-04-12 17:27:41.333 1135] FTL branch: master
[2019-04-12 17:27:41.333 1135] FTL commit: aae487e
[2019-04-12 17:27:41.333 1135] FTL date: 2019-02-25 17:18:14 -0800
[2019-04-12 17:27:41.333 1135] FTL user: pihole
[2019-04-12 17:27:41.333 1135] FTL version: v4.2.3
[2019-04-12 17:27:41.333 1135] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-04-12 17:27:41.333 1135] Using log file /var/log/pihole-FTL.log
[2019-04-12 17:27:41.334 1135] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-04-12 17:27:41.334 1135] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-04-12 17:27:41.334 1135] PORTFILE: Using /var/run/pihole-FTL.port
[2019-04-12 17:27:41.334 1135] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-04-12 17:27:41.343 1135] Resizing "/FTL-strings" from 4096 to 8192
[2019-04-12 17:27:41.345 1135] Resizing "/FTL-strings" from 8192 to 12288
[2019-04-12 17:27:41.349 1135] Resizing "/FTL-strings" from 12288 to 16384
[2019-04-12 17:27:41.356 1135] Resizing "/FTL-strings" from 16384 to 20480
[2019-04-12 17:27:41.367 1135] Resizing "/FTL-strings" from 20480 to 24576
[2019-04-12 17:27:41.384 1135] Resizing "/FTL-strings" from 24576 to 28672
[2019-04-12 17:27:41.394 1135] Resizing "/FTL-queries" from 229376 to 458752
[2019-04-12 17:27:41.407 1135] Resizing "/FTL-strings" from 28672 to 32768
[2019-04-12 17:27:41.433 1135] Resizing "/FTL-strings" from 32768 to 36864
[2019-04-12 17:27:41.470 1135] Resizing "/FTL-strings" from 36864 to 40960
[2019-04-12 17:27:41.479 1135] Resizing "/FTL-queries" from 458752 to 688128
[2019-04-12 17:27:41.562 1135] Resizing "/FTL-queries" from 688128 to 917504
[2019-04-12 17:27:41.624 1135] Resizing "/FTL-strings" from 40960 to 45056
[2019-04-12 17:27:41.639 1135] Resizing "/FTL-queries" from 917504 to 1146880
[2019-04-12 17:27:41.709 1135] Resizing "/FTL-strings" from 45056 to 49152
[2019-04-12 17:27:41.728 1135] Resizing "/FTL-queries" from 1146880 to 1376256
[2019-04-12 17:27:41.762 1135] Resizing "/FTL-strings" from 49152 to 53248
[2019-04-12 17:27:41.813 1135] Resizing "/FTL-strings" from 53248 to 57344
[2019-04-12 17:27:41.849 1135] Resizing "/FTL-queries" from 1376256 to 1605632
[2019-04-12 17:27:41.873 1135] Resizing "/FTL-strings" from 57344 to 61440
[2019-04-12 17:27:41.975 1135] Resizing "/FTL-queries" from 1605632 to 1835008
[2019-04-12 17:27:41.995 1135] Resizing "/FTL-strings" from 61440 to 65536
[2019-04-12 17:27:42.101 1135] Resizing "/FTL-queries" from 1835008 to 2064384
[2019-04-12 17:27:42.137 1135] Resizing "/FTL-strings" from 65536 to 69632
[2019-04-12 17:27:42.230 1135] Resizing "/FTL-queries" from 2064384 to 2293760
[2019-04-12 17:27:42.237 1135] Resizing "/FTL-strings" from 69632 to 73728
[2019-04-12 17:32:49.758 2179] ########## FTL started! ##########
[2019-04-12 17:32:49.758 2179] FTL branch: master
[2019-04-12 17:32:49.758 2179] FTL commit: aae487e
[2019-04-12 17:32:49.758 2179] FTL date: 2019-02-25 17:18:14 -0800
[2019-04-12 17:32:49.758 2179] FTL user: pihole
[2019-04-12 17:32:49.758 2179] FTL version: v4.2.3
[2019-04-12 17:32:49.758 2179] Using log file /var/log/pihole-FTL.log
[2019-04-12 17:32:49.759 2179] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-04-12 17:32:49.759 2179] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-04-12 17:32:49.760 2179] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-04-12 17:32:49.760 2179] PORTFILE: Using /var/run/pihole-FTL.port
[2019-04-12 17:32:49.760 2179] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-04-12 17:32:49.768 2179] Resizing "/FTL-strings" from 4096 to 8192
[2019-04-12 17:32:49.769 2179] Resizing "/FTL-strings" from 8192 to 12288
[2019-04-12 17:32:49.773 2179] Resizing "/FTL-strings" from 12288 to 16384
[2019-04-12 17:32:49.780 2179] Resizing "/FTL-strings" from 16384 to 20480
[2019-04-12 17:32:49.793 2179] Resizing "/FTL-strings" from 20480 to 24576
[2019-04-12 17:32:49.810 2179] Resizing "/FTL-strings" from 24576 to 28672
[2019-04-12 17:32:49.822 2179] Resizing "/FTL-queries" from 229376 to 458752
[2019-04-12 17:32:49.835 2179] Resizing "/FTL-strings" from 28672 to 32768
[2019-04-12 17:32:49.859 2179] Resizing "/FTL-strings" from 32768 to 36864
[2019-04-12 17:32:49.898 2179] Resizing "/FTL-strings" from 36864 to 40960
[2019-04-12 17:32:49.909 2179] Resizing "/FTL-queries" from 458752 to 688128
[2019-04-12 17:32:49.998 2179] Resizing "/FTL-queries" from 688128 to 917504
[2019-04-12 17:32:50.079 2179] Resizing "/FTL-queries" from 917504 to 1146880
[2019-04-12 17:32:50.097 2179] Resizing "/FTL-strings" from 40960 to 45056
[2019-04-12 17:32:50.147 2179] Resizing "/FTL-strings" from 45056 to 49152
[2019-04-12 17:32:50.168 2179] Resizing "/FTL-queries" from 1146880 to 1376256
[2019-04-12 17:32:50.205 2179] Resizing "/FTL-strings" from 49152 to 53248
[2019-04-12 17:32:50.251 2179] Resizing "/FTL-strings" from 53248 to 57344
[2019-04-12 17:32:50.291 2179] Resizing "/FTL-queries" from 1376256 to 1605632
[2019-04-12 17:32:50.318 2179] Resizing "/FTL-strings" from 57344 to 61440
[2019-04-12 17:32:50.420 2179] Resizing "/FTL-queries" from 1605632 to 1835008
[2019-04-12 17:32:50.438 2179] Resizing "/FTL-strings" from 61440 to 65536
[2019-04-12 17:32:50.553 2179] Resizing "/FTL-queries" from 1835008 to 2064384
[2019-04-12 17:32:50.605 2179] Resizing "/FTL-strings" from 65536 to 69632
[2019-04-12 17:32:50.682 2179] Resizing "/FTL-queries" from 2064384 to 2293760
[2019-04-12 17:32:50.689 2179] Resizing "/FTL-strings" from 69632 to 73728
[2019-04-12 17:38:44.167 2677] Using log file /var/log/pihole-FTL.log
[2019-04-12 17:38:44.168 2677] ########## FTL started! ##########
[2019-04-12 17:38:44.168 2677] FTL branch: master
[2019-04-12 17:38:44.168 2677] FTL commit: aae487e
[2019-04-12 17:38:44.168 2677] FTL date: 2019-02-25 17:18:14 -0800
[2019-04-12 17:38:44.168 2677] FTL user: pihole
[2019-04-12 17:38:44.168 2677] FTL version: v4.2.3
[2019-04-12 17:38:44.168 2677] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-04-12 17:38:44.169 2677] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-04-12 17:38:44.169 2677] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-04-12 17:38:44.169 2677] PORTFILE: Using /var/run/pihole-FTL.port
[2019-04-12 17:38:44.169 2677] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-04-12 17:38:44.176 2677] Resizing "/FTL-strings" from 4096 to 8192
[2019-04-12 17:38:44.177 2677] Resizing "/FTL-strings" from 8192 to 12288
[2019-04-12 17:38:44.182 2677] Resizing "/FTL-strings" from 12288 to 16384
[2019-04-12 17:38:44.189 2677] Resizing "/FTL-strings" from 16384 to 20480
[2019-04-12 17:38:44.202 2677] Resizing "/FTL-strings" from 20480 to 24576
[2019-04-12 17:38:44.219 2677] Resizing "/FTL-strings" from 24576 to 28672
[2019-04-12 17:38:44.233 2677] Resizing "/FTL-queries" from 229376 to 458752
[2019-04-12 17:38:44.241 2677] Resizing "/FTL-strings" from 28672 to 32768
[2019-04-12 17:38:44.265 2677] Resizing "/FTL-strings" from 32768 to 36864
[2019-04-12 17:38:44.305 2677] Resizing "/FTL-strings" from 36864 to 40960
[2019-04-12 17:38:44.317 2677] Resizing "/FTL-queries" from 458752 to 688128
[2019-04-12 17:38:44.400 2677] Resizing "/FTL-queries" from 688128 to 917504
[2019-04-12 17:38:44.477 2677] Resizing "/FTL-queries" from 917504 to 1146880
[2019-04-12 17:38:44.500 2677] Resizing "/FTL-strings" from 40960 to 45056
[2019-04-12 17:38:44.542 2677] Resizing "/FTL-strings" from 45056 to 49152
[2019-04-12 17:38:44.568 2677] Resizing "/FTL-queries" from 1146880 to 1376256
[2019-04-12 17:38:44.606 2677] Resizing "/FTL-strings" from 49152 to 53248
[2019-04-12 17:38:44.653 2677] Resizing "/FTL-strings" from 53248 to 57344
[2019-04-12 17:38:44.695 2677] Resizing "/FTL-queries" from 1376256 to 1605632
[2019-04-12 17:38:44.720 2677] Resizing "/FTL-strings" from 57344 to 61440
[2019-04-12 17:38:44.820 2677] Resizing "/FTL-queries" from 1605632 to 1835008
[2019-04-12 17:38:44.830 2677] Resizing "/FTL-strings" from 61440 to 65536
[2019-04-12 17:38:44.943 2677] Resizing "/FTL-queries" from 1835008 to 2064384
[2019-04-12 17:38:44.990 2677] Resizing "/FTL-strings" from 65536 to 69632
[2019-04-12 17:38:45.069 2677] Resizing "/FTL-queries" from 2064384 to 2293760
[2019-04-12 17:38:45.073 2677] Resizing "/FTL-strings" from 69632 to 73728
[2019-04-12 17:48:28.883 4148] Using log file /var/log/pihole-FTL.log
[2019-04-12 17:48:28.884 4148] ########## FTL started! ##########
[2019-04-12 17:48:28.884 4148] FTL branch: master
[2019-04-12 17:48:28.884 4148] FTL commit: aae487e
[2019-04-12 17:48:28.884 4148] FTL date: 2019-02-25 17:18:14 -0800
[2019-04-12 17:48:28.884 4148] FTL user: pihole
[2019-04-12 17:48:28.884 4148] FTL version: v4.2.3
[2019-04-12 17:48:28.884 4148] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-04-12 17:48:28.885 4148] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-04-12 17:48:28.885 4148] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-04-12 17:48:28.885 4148] PORTFILE: Using /var/run/pihole-FTL.port
[2019-04-12 17:48:28.885 4148] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-04-12 17:48:28.890 4148] Resizing "/FTL-strings" from 4096 to 8192
[2019-04-12 17:48:28.891 4148] Resizing "/FTL-strings" from 8192 to 12288
[2019-04-12 17:48:28.896 4148] Resizing "/FTL-strings" from 12288 to 16384
[2019-04-12 17:48:28.903 4148] Resizing "/FTL-strings" from 16384 to 20480
[2019-04-12 17:48:28.917 4148] Resizing "/FTL-strings" from 20480 to 24576
[2019-04-12 17:48:28.935 4148] Resizing "/FTL-strings" from 24576 to 28672
[2019-04-12 17:48:28.953 4148] Resizing "/FTL-queries" from 229376 to 458752
[2019-04-12 17:48:28.956 4148] Resizing "/FTL-strings" from 28672 to 32768
[2019-04-12 17:48:28.980 4148] Resizing "/FTL-strings" from 32768 to 36864
[2019-04-12 17:48:29.028 4148] Resizing "/FTL-strings" from 36864 to 40960
[2019-04-12 17:48:29.036 4148] Resizing "/FTL-queries" from 458752 to 688128
[2019-04-12 17:48:29.124 4148] Resizing "/FTL-queries" from 688128 to 917504
[2019-04-12 17:48:29.208 4148] Resizing "/FTL-queries" from 917504 to 1146880
[2019-04-12 17:48:29.231 4148] Resizing "/FTL-strings" from 40960 to 45056
[2019-04-12 17:48:29.274 4148] Resizing "/FTL-strings" from 45056 to 49152
[2019-04-12 17:48:29.306 4148] Resizing "/FTL-queries" from 1146880 to 1376256
[2019-04-12 17:48:29.340 4148] Resizing "/FTL-strings" from 49152 to 53248
[2019-04-12 17:48:29.383 4148] Resizing "/FTL-strings" from 53248 to 57344
[2019-04-12 17:48:29.435 4148] Resizing "/FTL-queries" from 1376256 to 1605632
[2019-04-12 17:48:29.456 4148] Resizing "/FTL-strings" from 57344 to 61440
[2019-04-12 17:48:29.565 4148] Resizing "/FTL-queries" from 1605632 to 1835008
[2019-04-12 17:48:29.565 4148] Resizing "/FTL-strings" from 61440 to 65536
[2019-04-12 17:48:29.688 4148] Resizing "/FTL-queries" from 1835008 to 2064384
[2019-04-12 17:48:29.732 4148] Resizing "/FTL-strings" from 65536 to 69632
[2019-04-12 17:48:29.815 4148] Resizing "/FTL-strings" from 69632 to 73728
[2019-04-12 17:48:29.821 4148] Resizing "/FTL-queries" from 2064384 to 2293760
[2019-04-12 17:53:21.044 799] Using log file /var/log/pihole-FTL.log
[2019-04-12 17:53:21.045 799] ########## FTL started! ##########
[2019-04-12 17:53:21.045 799] FTL branch: master
[2019-04-12 17:53:21.046 799] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-04-12 17:53:21.046 799] FTL commit: aae487e
[2019-04-12 17:53:21.046 799] FTL date: 2019-02-25 17:18:14 -0800
[2019-04-12 17:53:21.046 799] FTL user: pihole
[2019-04-12 17:53:21.046 799] FTL version: v4.2.3
[2019-04-12 17:53:21.046 799] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-04-12 17:53:21.047 799] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-04-12 17:53:21.047 799] PORTFILE: Using /var/run/pihole-FTL.port
[2019-04-12 17:53:21.047 799] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-04-12 17:53:21.097 799] Resizing "/FTL-strings" from 4096 to 8192
[2019-04-12 17:53:21.101 799] Resizing "/FTL-strings" from 8192 to 12288
[2019-04-12 17:53:21.105 799] Resizing "/FTL-strings" from 12288 to 16384
[2019-04-12 17:53:21.113 799] Resizing "/FTL-strings" from 16384 to 20480
[2019-04-12 17:53:21.128 799] Resizing "/FTL-strings" from 20480 to 24576
[2019-04-12 17:53:21.146 799] Resizing "/FTL-strings" from 24576 to 28672
[2019-04-12 17:53:21.167 799] Resizing "/FTL-queries" from 229376 to 458752
[2019-04-12 17:53:21.168 799] Resizing "/FTL-strings" from 28672 to 32768
[2019-04-12 17:53:21.193 799] Resizing "/FTL-strings" from 32768 to 36864
[2019-04-12 17:53:21.251 799] Resizing "/FTL-queries" from 458752 to 688128
[2019-04-12 17:53:21.260 799] Resizing "/FTL-strings" from 36864 to 40960
[2019-04-12 17:53:21.340 799] Resizing "/FTL-queries" from 688128 to 917504
[2019-04-12 17:53:21.427 799] Resizing "/FTL-queries" from 917504 to 1146880
[2019-04-12 17:53:21.450 799] Resizing "/FTL-strings" from 40960 to 45056
[2019-04-12 17:53:21.492 799] Resizing "/FTL-strings" from 45056 to 49152
[2019-04-12 17:53:21.527 799] Resizing "/FTL-queries" from 1146880 to 1376256
[2019-04-12 17:53:21.562 799] Resizing "/FTL-strings" from 49152 to 53248
[2019-04-12 17:53:21.604 799] Resizing "/FTL-strings" from 53248 to 57344
[2019-04-12 17:53:21.655 799] Resizing "/FTL-queries" from 1376256 to 1605632
[2019-04-12 17:53:21.678 799] Resizing "/FTL-strings" from 57344 to 61440
[2019-04-12 17:53:21.789 799] Resizing "/FTL-queries" from 1605632 to 1835008
[2019-04-12 17:53:21.802 799] Resizing "/FTL-strings" from 61440 to 65536
[2019-04-12 17:53:21.911 799] Resizing "/FTL-queries" from 1835008 to 2064384
[2019-04-12 17:53:21.956 799] Resizing "/FTL-strings" from 65536 to 69632
[2019-04-12 17:53:22.037 799] Resizing "/FTL-strings" from 69632 to 73728
[2019-04-12 17:53:22.045 799] Resizing "/FTL-queries" from 2064384 to 2293760
[2019-04-12 17:54:59.757 994] ########## FTL started! ##########
[2019-04-12 17:54:59.757 994] FTL branch: master
[2019-04-12 17:54:59.757 994] FTL commit: aae487e
[2019-04-12 17:54:59.757 994] FTL date: 2019-02-25 17:18:14 -0800
[2019-04-12 17:54:59.757 994] FTL user: pihole
[2019-04-12 17:54:59.757 994] FTL version: v4.2.3
[2019-04-12 17:54:59.757 994] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-04-12 17:54:59.757 994] Using log file /var/log/pihole-FTL.log
[2019-04-12 17:54:59.758 994] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-04-12 17:54:59.758 994] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-04-12 17:54:59.758 994] PORTFILE: Using /var/run/pihole-FTL.port
[2019-04-12 17:54:59.758 994] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-04-12 17:54:59.762 994] Resizing "/FTL-strings" from 4096 to 8192
[2019-04-12 17:54:59.764 994] Resizing "/FTL-strings" from 8192 to 12288
[2019-04-12 17:54:59.768 994] Resizing "/FTL-strings" from 12288 to 16384
[2019-04-12 17:54:59.776 994] Resizing "/FTL-strings" from 16384 to 20480
[2019-04-12 17:54:59.791 994] Resizing "/FTL-strings" from 20480 to 24576
[2019-04-12 17:54:59.809 994] Resizing "/FTL-strings" from 24576 to 28672
[2019-04-12 17:54:59.830 994] Resizing "/FTL-queries" from 229376 to 458752
[2019-04-12 17:54:59.831 994] Resizing "/FTL-strings" from 28672 to 32768
[2019-04-12 17:54:59.855 994] Resizing "/FTL-strings" from 32768 to 36864
[2019-04-12 17:54:59.913 994] Resizing "/FTL-queries" from 458752 to 688128
[2019-04-12 17:54:59.924 994] Resizing "/FTL-strings" from 36864 to 40960
[2019-04-12 17:55:00.001 994] Resizing "/FTL-queries" from 688128 to 917504
[2019-04-12 17:55:00.085 994] Resizing "/FTL-queries" from 917504 to 1146880
[2019-04-12 17:55:00.107 994] Resizing "/FTL-strings" from 40960 to 45056
[2019-04-12 17:55:00.147 994] Resizing "/FTL-strings" from 45056 to 49152
[2019-04-12 17:55:00.183 994] Resizing "/FTL-queries" from 1146880 to 1376256
[2019-04-12 17:55:00.217 994] Resizing "/FTL-strings" from 49152 to 53248
[2019-04-12 17:55:00.260 994] Resizing "/FTL-strings" from 53248 to 57344
[2019-04-12 17:55:00.313 994] Resizing "/FTL-queries" from 1376256 to 1605632
[2019-04-12 17:55:00.334 994] Resizing "/FTL-strings" from 57344 to 61440
[2019-04-12 17:55:00.445 994] Resizing "/FTL-queries" from 1605632 to 1835008
[2019-04-12 17:55:00.457 994] Resizing "/FTL-strings" from 61440 to 65536
[2019-04-12 17:55:00.567 994] Resizing "/FTL-queries" from 1835008 to 2064384
[2019-04-12 17:55:00.609 994] Resizing "/FTL-strings" from 65536 to 69632
[2019-04-12 17:55:00.689 994] Resizing "/FTL-strings" from 69632 to 73728
[2019-04-12 17:55:00.698 994] Resizing "/FTL-queries" from 2064384 to 2293760
[2019-04-12 17:56:28.980 1141] ########## FTL started! ##########
[2019-04-12 17:56:28.980 1141] FTL branch: master
[2019-04-12 17:56:28.980 1141] Using log file /var/log/pihole-FTL.log
[2019-04-12 17:56:28.981 1141] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-04-12 17:56:28.981 1141] FTL commit: aae487e
[2019-04-12 17:56:28.981 1141] FTL date: 2019-02-25 17:18:14 -0800
[2019-04-12 17:56:28.981 1141] FTL user: pihole
[2019-04-12 17:56:28.981 1141] FTL version: v4.2.3
[2019-04-12 17:56:28.981 1141] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-04-12 17:56:28.982 1141] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-04-12 17:56:28.982 1141] PORTFILE: Using /var/run/pihole-FTL.port
[2019-04-12 17:56:28.982 1141] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-04-12 17:56:28.985 1141] Resizing "/FTL-strings" from 4096 to 8192
[2019-04-12 17:56:28.987 1141] Resizing "/FTL-strings" from 8192 to 12288
[2019-04-12 17:56:28.992 1141] Resizing "/FTL-strings" from 12288 to 16384
[2019-04-12 17:56:29.000 1141] Resizing "/FTL-strings" from 16384 to 20480
[2019-04-12 17:56:29.015 1141] Resizing "/FTL-strings" from 20480 to 24576
[2019-04-12 17:56:29.032 1141] Resizing "/FTL-strings" from 24576 to 28672
[2019-04-12 17:56:29.054 1141] Resizing "/FTL-strings" from 28672 to 32768
[2019-04-12 17:56:29.055 1141] Resizing "/FTL-queries" from 229376 to 458752
[2019-04-12 17:56:29.078 1141] Resizing "/FTL-strings" from 32768 to 36864
[2019-04-12 17:56:29.138 1141] Resizing "/FTL-queries" from 458752 to 688128
[2019-04-12 17:56:29.148 1141] Resizing "/FTL-strings" from 36864 to 40960
[2019-04-12 17:56:29.227 1141] Resizing "/FTL-queries" from 688128 to 917504
[2019-04-12 17:56:29.312 1141] Resizing "/FTL-queries" from 917504 to 1146880
[2019-04-12 17:56:29.334 1141] Resizing "/FTL-strings" from 40960 to 45056
[2019-04-12 17:56:29.375 1141] Resizing "/FTL-strings" from 45056 to 49152
[2019-04-12 17:56:29.412 1141] Resizing "/FTL-queries" from 1146880 to 1376256
[2019-04-12 17:56:29.445 1141] Resizing "/FTL-strings" from 49152 to 53248
[2019-04-12 17:56:29.489 1141] Resizing "/FTL-strings" from 53248 to 57344
[2019-04-12 17:56:29.544 1141] Resizing "/FTL-queries" from 1376256 to 1605632
[2019-04-12 17:56:29.564 1141] Resizing "/FTL-strings" from 57344 to 61440
[2019-04-12 17:56:29.676 1141] Resizing "/FTL-queries" from 1605632 to 1835008
[2019-04-12 17:56:29.687 1141] Resizing "/FTL-strings" from 61440 to 65536
[2019-04-12 17:56:29.800 1141] Resizing "/FTL-queries" from 1835008 to 2064384
[2019-04-12 17:56:29.841 1141] Resizing "/FTL-strings" from 65536 to 69632
[2019-04-12 17:56:29.921 1141] Resizing "/FTL-strings" from 69632 to 73728
[2019-04-12 17:56:29.932 1141] Resizing "/FTL-queries" from 2064384 to 2293760
[2019-04-12 18:00:41.395 1974] ########## FTL started! ##########
[2019-04-12 18:00:41.395 1974] FTL branch: master
[2019-04-12 18:00:41.395 1974] FTL commit: aae487e
[2019-04-12 18:00:41.395 1974] FTL date: 2019-02-25 17:18:14 -0800
[2019-04-12 18:00:41.395 1974] FTL user: pihole
[2019-04-12 18:00:41.395 1974] FTL version: v4.2.3
[2019-04-12 18:00:41.395 1974] Using log file /var/log/pihole-FTL.log
[2019-04-12 18:00:41.396 1974] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-04-12 18:00:41.396 1974] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-04-12 18:00:41.397 1974] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-04-12 18:00:41.397 1974] PORTFILE: Using /var/run/pihole-FTL.port
[2019-04-12 18:00:41.397 1974] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-04-12 18:00:41.400 1974] Resizing "/FTL-strings" from 4096 to 8192
[2019-04-12 18:00:41.403 1974] Resizing "/FTL-strings" from 8192 to 12288
[2019-04-12 18:00:41.410 1974] Resizing "/FTL-strings" from 12288 to 16384
[2019-04-12 18:00:41.422 1974] Resizing "/FTL-strings" from 16384 to 20480
[2019-04-12 18:00:41.439 1974] Resizing "/FTL-strings" from 20480 to 24576
[2019-04-12 18:00:41.457 1974] Resizing "/FTL-strings" from 24576 to 28672
[2019-04-12 18:00:41.465 1974] Resizing "/FTL-queries" from 229376 to 458752
[2019-04-12 18:00:41.480 1974] Resizing "/FTL-strings" from 28672 to 32768
[2019-04-12 18:00:41.518 1974] Resizing "/FTL-strings" from 32768 to 36864
[2019-04-12 18:00:41.547 1974] Resizing "/FTL-queries" from 458752 to 688128
[2019-04-12 18:00:41.635 1974] Resizing "/FTL-queries" from 688128 to 917504
[2019-04-12 18:00:41.697 1974] Resizing "/FTL-strings" from 36864 to 40960
[2019-04-12 18:00:41.718 1974] Resizing "/FTL-queries" from 917504 to 1146880
[2019-04-12 18:00:41.768 1974] Resizing "/FTL-strings" from 40960 to 45056
[2019-04-12 18:00:41.817 1974] Resizing "/FTL-queries" from 1146880 to 1376256
[2019-04-12 18:00:41.823 1974] Resizing "/FTL-strings" from 45056 to 49152
[2019-04-12 18:00:41.871 1974] Resizing "/FTL-strings" from 49152 to 53248
[2019-04-12 18:00:41.930 1974] Resizing "/FTL-strings" from 53248 to 57344
[2019-04-12 18:00:41.949 1974] Resizing "/FTL-queries" from 1376256 to 1605632
[2019-04-12 18:00:42.053 1974] Resizing "/FTL-strings" from 57344 to 61440
[2019-04-12 18:00:42.073 1974] Resizing "/FTL-queries" from 1605632 to 1835008
[2019-04-12 18:00:42.198 1974] Resizing "/FTL-queries" from 1835008 to 2064384
[2019-04-12 18:00:42.200 1974] Resizing "/FTL-strings" from 61440 to 65536
[2019-04-12 18:00:42.292 1974] Resizing "/FTL-strings" from 65536 to 69632
[2019-04-12 18:00:42.324 1974] Resizing "/FTL-queries" from 2064384 to 2293760
[2019-04-12 18:02:16.434 2352] ########## FTL started! ##########
[2019-04-12 18:02:16.434 2352] FTL branch: master
[2019-04-12 18:02:16.434 2352] FTL commit: aae487e
[2019-04-12 18:02:16.434 2352] FTL date: 2019-02-25 17:18:14 -0800
[2019-04-12 18:02:16.434 2352] FTL user: pihole
[2019-04-12 18:02:16.434 2352] FTL version: v4.2.3
[2019-04-12 18:02:16.434 2352] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-04-12 18:02:16.434 2352] Using log file /var/log/pihole-FTL.log
[2019-04-12 18:02:16.435 2352] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-04-12 18:02:16.435 2352] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-04-12 18:02:16.435 2352] PORTFILE: Using /var/run/pihole-FTL.port
[2019-04-12 18:02:16.435 2352] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-04-12 18:02:16.440 2352] Resizing "/FTL-strings" from 4096 to 8192
[2019-04-12 18:02:16.445 2352] Resizing "/FTL-strings" from 8192 to 12288
[2019-04-12 18:02:16.455 2352] Resizing "/FTL-strings" from 12288 to 16384
[2019-04-12 18:02:16.469 2352] Resizing "/FTL-strings" from 16384 to 20480
[2019-04-12 18:02:16.484 2352] Resizing "/FTL-strings" from 20480 to 24576
[2019-04-12 18:02:16.497 2352] Resizing "/FTL-queries" from 229376 to 458752
[2019-04-12 18:02:16.505 2352] Resizing "/FTL-strings" from 24576 to 28672
[2019-04-12 18:02:16.538 2352] Resizing "/FTL-strings" from 28672 to 32768
[2019-04-12 18:02:16.571 2352] Resizing "/FTL-queries" from 458752 to 688128
[2019-04-12 18:02:16.648 2352] Resizing "/FTL-strings" from 32768 to 36864
[2019-04-12 18:02:16.652 2352] Resizing "/FTL-queries" from 688128 to 917504
[2019-04-12 18:02:16.728 2352] Resizing "/FTL-queries" from 917504 to 1146880
[2019-04-12 18:02:16.751 2352] Resizing "/FTL-strings" from 36864 to 40960
[2019-04-12 18:02:16.782 2352] Resizing "/FTL-strings" from 40960 to 45056
[2019-04-12 18:02:16.826 2352] Resizing "/FTL-queries" from 1146880 to 1376256
[2019-04-12 18:02:16.854 2352] Resizing "/FTL-strings" from 45056 to 49152
[2019-04-12 18:02:16.894 2352] Resizing "/FTL-strings" from 49152 to 53248
[2019-04-12 18:02:16.951 2352] Resizing "/FTL-queries" from 1376256 to 1605632
[2019-04-12 18:02:16.971 2352] Resizing "/FTL-strings" from 53248 to 57344
[2019-04-12 18:02:17.073 2352] Resizing "/FTL-queries" from 1605632 to 1835008
[2019-04-12 18:02:17.078 2352] Resizing "/FTL-strings" from 57344 to 61440
[2019-04-12 18:02:17.200 2352] Resizing "/FTL-queries" from 1835008 to 2064384
[2019-04-12 18:02:17.244 2352] Resizing "/FTL-strings" from 61440 to 65536
[2019-04-12 18:02:17.316 2352] Resizing "/FTL-strings" from 65536 to 69632
[2019-04-12 18:02:17.328 2352] Resizing "/FTL-queries" from 2064384 to 2293760
[2019-04-12 18:03:16.015 3005] ########## FTL started! ##########
[2019-04-12 18:03:16.015 3005] FTL branch: master
[2019-04-12 18:03:16.015 3005] FTL commit: aae487e
[2019-04-12 18:03:16.015 3005] FTL date: 2019-02-25 17:18:14 -0800
[2019-04-12 18:03:16.015 3005] FTL user: pihole
[2019-04-12 18:03:16.015 3005] FTL version: v4.2.3
[2019-04-12 18:03:16.015 3005] Using log file /var/log/pihole-FTL.log
[2019-04-12 18:03:16.016 3005] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-04-12 18:03:16.016 3005] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-04-12 18:03:16.017 3005] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-04-12 18:03:16.017 3005] PORTFILE: Using /var/run/pihole-FTL.port
[2019-04-12 18:03:16.017 3005] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-04-12 18:03:16.022 3005] Resizing "/FTL-strings" from 4096 to 8192
[2019-04-12 18:03:16.027 3005] Resizing "/FTL-strings" from 8192 to 12288
[2019-04-12 18:03:16.037 3005] Resizing "/FTL-strings" from 12288 to 16384
[2019-04-12 18:03:16.050 3005] Resizing "/FTL-strings" from 16384 to 20480
[2019-04-12 18:03:16.066 3005] Resizing "/FTL-strings" from 20480 to 24576
[2019-04-12 18:03:16.079 3005] Resizing "/FTL-queries" from 229376 to 458752
[2019-04-12 18:03:16.088 3005] Resizing "/FTL-strings" from 24576 to 28672
[2019-04-12 18:03:16.122 3005] Resizing "/FTL-strings" from 28672 to 32768
[2019-04-12 18:03:16.158 3005] Resizing "/FTL-queries" from 458752 to 688128
[2019-04-12 18:03:16.240 3005] Resizing "/FTL-strings" from 32768 to 36864
[2019-04-12 18:03:16.244 3005] Resizing "/FTL-queries" from 688128 to 917504
[2019-04-12 18:03:16.326 3005] Resizing "/FTL-queries" from 917504 to 1146880
[2019-04-12 18:03:16.351 3005] Resizing "/FTL-strings" from 36864 to 40960
[2019-04-12 18:03:16.385 3005] Resizing "/FTL-strings" from 40960 to 45056
[2019-04-12 18:03:16.430 3005] Resizing "/FTL-queries" from 1146880 to 1376256
[2019-04-12 18:03:16.459 3005] Resizing "/FTL-strings" from 45056 to 49152
[2019-04-12 18:03:16.500 3005] Resizing "/FTL-strings" from 49152 to 53248
[2019-04-12 18:03:16.559 3005] Resizing "/FTL-queries" from 1376256 to 1605632
[2019-04-12 18:03:16.579 3005] Resizing "/FTL-strings" from 53248 to 57344
[2019-04-12 18:03:16.684 3005] Resizing "/FTL-queries" from 1605632 to 1835008
[2019-04-12 18:03:16.688 3005] Resizing "/FTL-strings" from 57344 to 61440
[2019-04-12 18:03:16.812 3005] Resizing "/FTL-queries" from 1835008 to 2064384
[2019-04-12 18:03:16.855 3005] Resizing "/FTL-strings" from 61440 to 65536
[2019-04-12 18:03:16.929 3005] Resizing "/FTL-strings" from 65536 to 69632
[2019-04-12 18:03:16.942 3005] Resizing "/FTL-queries" from 2064384 to 2293760
jfb
April 13, 2019, 1:05am
6
What is the output of: journalctl -u pihole-FTL
-- Logs begin at Fri 2019-04-12 17:53:07 CDT, end at Fri 2019-04-12 20:06:09 CDT. --
Apr 12 17:53:09 raspberrypi systemd[1]: Starting LSB: pihole-FTL daemon...
Apr 12 17:53:09 raspberrypi pihole-FTL[359]: Not running
Apr 12 17:53:20 raspberrypi su[786]: Successful su for pihole by root
Apr 12 17:53:20 raspberrypi su[786]: + ??? root:pihole
Apr 12 17:53:20 raspberrypi su[786]: pam_unix(su:session): session opened for user pihole by (uid=0)
Apr 12 17:53:22 raspberrypi pihole-FTL[359]: dnsmasq: cannot read /etc/dnsmasq.d/02-ovpn.conf.save: Permission denied
Apr 12 17:53:22 raspberrypi systemd[1]: Started LSB: pihole-FTL daemon.
Apr 12 17:54:59 raspberrypi systemd[1]: Stopping LSB: pihole-FTL daemon...
Apr 12 17:54:59 raspberrypi pihole-FTL[948]: Not running
Apr 12 17:54:59 raspberrypi systemd[1]: Stopped LSB: pihole-FTL daemon.
Apr 12 17:54:59 raspberrypi systemd[1]: Starting LSB: pihole-FTL daemon...
Apr 12 17:54:59 raspberrypi pihole-FTL[953]: Not running
Apr 12 17:54:59 raspberrypi su[981]: Successful su for pihole by root
Apr 12 17:54:59 raspberrypi su[981]: + ??? root:pihole
Apr 12 17:54:59 raspberrypi su[981]: pam_unix(su:session): session opened for user pihole by (uid=0)
Apr 12 17:55:00 raspberrypi pihole-FTL[953]: dnsmasq: cannot read /etc/dnsmasq.d/02-ovpn.conf.save: Permission denied
Apr 12 17:55:00 raspberrypi systemd[1]: Started LSB: pihole-FTL daemon.
Apr 12 17:56:28 raspberrypi systemd[1]: Stopping LSB: pihole-FTL daemon...
Apr 12 17:56:28 raspberrypi pihole-FTL[1095]: Not running
Apr 12 17:56:28 raspberrypi systemd[1]: Stopped LSB: pihole-FTL daemon.
Apr 12 17:56:28 raspberrypi systemd[1]: Starting LSB: pihole-FTL daemon...
Apr 12 17:56:28 raspberrypi pihole-FTL[1101]: Not running
Apr 12 17:56:28 raspberrypi su[1128]: Successful su for pihole by root
Apr 12 17:56:28 raspberrypi su[1128]: + ??? root:pihole
Apr 12 17:56:28 raspberrypi su[1128]: pam_unix(su:session): session opened for user pihole by (uid=0)
Apr 12 17:56:29 raspberrypi pihole-FTL[1101]: dnsmasq: cannot read /etc/dnsmasq.d/02-ovpn.conf.save: Permission denied
Apr 12 17:56:29 raspberrypi systemd[1]: Started LSB: pihole-FTL daemon.
Apr 12 18:00:24 raspberrypi systemd[1]: Stopping LSB: pihole-FTL daemon...
Apr 12 18:00:24 raspberrypi pihole-FTL[1714]: Not running
Apr 12 18:00:25 raspberrypi systemd[1]: Stopped LSB: pihole-FTL daemon.
Apr 12 18:00:41 raspberrypi systemd[1]: Starting LSB: pihole-FTL daemon...
Apr 12 18:00:41 raspberrypi pihole-FTL[1934]: Not running
Apr 12 18:00:41 raspberrypi su[1961]: Successful su for pihole by root
Apr 12 18:00:41 raspberrypi su[1961]: + ??? root:pihole
Apr 12 18:00:41 raspberrypi su[1961]: pam_unix(su:session): session opened for user pihole by (uid=0)
Apr 12 18:00:42 raspberrypi pihole-FTL[1934]: dnsmasq: cannot read /etc/dnsmasq.d/02-ovpn.conf.save: Permission denied
Apr 12 18:00:42 raspberrypi systemd[1]: Started LSB: pihole-FTL daemon.
Apr 12 18:02:15 raspberrypi systemd[1]: Stopping LSB: pihole-FTL daemon...
Apr 12 18:02:16 raspberrypi pihole-FTL[2303]: Not running
Apr 12 18:02:16 raspberrypi systemd[1]: Stopped LSB: pihole-FTL daemon.
Apr 12 18:02:16 raspberrypi systemd[1]: Starting LSB: pihole-FTL daemon...
Apr 12 18:02:16 raspberrypi pihole-FTL[2312]: Not running
Apr 12 18:02:16 raspberrypi su[2339]: Successful su for pihole by root
Apr 12 18:02:16 raspberrypi su[2339]: + ??? root:pihole
Apr 12 18:02:16 raspberrypi su[2339]: pam_unix(su:session): session opened for user pihole by (uid=0)
Apr 12 18:02:17 raspberrypi pihole-FTL[2312]: dnsmasq: cannot read /etc/dnsmasq.d/02-ovpn.conf.save: Permission denied
Apr 12 18:02:17 raspberrypi systemd[1]: Started LSB: pihole-FTL daemon.
Apr 12 18:03:15 raspberrypi systemd[1]: Stopping LSB: pihole-FTL daemon...
Apr 12 18:03:15 raspberrypi pihole-FTL[2959]: Not running
Apr 12 18:03:15 raspberrypi systemd[1]: Stopped LSB: pihole-FTL daemon.
Apr 12 18:03:15 raspberrypi systemd[1]: Starting LSB: pihole-FTL daemon...
Apr 12 18:03:15 raspberrypi pihole-FTL[2965]: Not running
Apr 12 18:03:15 raspberrypi su[2992]: Successful su for pihole by root
Apr 12 18:03:15 raspberrypi su[2992]: + ??? root:pihole
Apr 12 18:03:15 raspberrypi su[2992]: pam_unix(su:session): session opened for user pihole by (uid=0)
Apr 12 18:03:16 raspberrypi pihole-FTL[2965]: dnsmasq: cannot read /etc/dnsmasq.d/02-ovpn.conf.save: Permission denied
Apr 12 18:03:16 raspberrypi systemd[1]: Started LSB: pihole-FTL daemon.
Okay, first of all -- updated debug token is ok201syiex!.
I have tried many things to correct the problem in the interim. The current status appears to be the same as when I first saw problems ("Lost Connection to API", DNS and FTL services not running).
At one point I was briefly able to get DNS and FTL showing as running after I ran sudo pihole-FTL test
which would immediately report success, but then the piHole admin web interface wouldn't load (it just tried to launch/refresh but would appear to be locked up).
Latest steps that got me to this point:
Reboot of Raspberry Pi.
Ran pihole status
and confirmed DNS not running.
Ran pihole -r
with the Reconfigure option.
At first, DNS service would not launch, but did so after a retry (I might have run pihole-FTL test in another window that could have triggered this success, can't remember for 100% sure)
No further errors reported, but DNS and FTL not running as stated above.
I then ran pihole -d
and posted here.
During my troubleshooting, I found an install of the apache2 package and removed it. I found after this that if I connected to my PI server at 192.168.1.200 (without the /Admin) it would load a default Debian Apache web page. I then removed apache2 again with the --purge option and it was gone from my dpkg list; then loading 192.168.1.200 without /Admin loaded the expected PiHole page ("did you mean to run /Admin" prompt would show). But PiHole services were still not running even after the above steps to reset, restart services, etc.
Thanks for help thus far.
Mcat12
April 13, 2019, 10:21pm
12
Remove /etc/dnsmasq.d/02-ovpn.conf.save
What is the output of these commands?
sudo service pihole-FTL stop
sudo -u pihole pihole-FTL no-daemon
sudo service pihole-FTL stop``
No output.
[2019-04-13 18:48:28.074 8774] Using log file /var/log/pihole-FTL.log
[2019-04-13 18:48:28.074 8774] ########## FTL started! ##########
[2019-04-13 18:48:28.074 8774] FTL branch: master
[2019-04-13 18:48:28.074 8774] FTL version: v4.2.3
[2019-04-13 18:48:28.075 8774] FTL commit: aae487e
[2019-04-13 18:48:28.075 8774] FTL date: 2019-02-25 17:18:14 -0800
[2019-04-13 18:48:28.075 8774] FTL user: pihole
[2019-04-13 18:48:28.076 8774] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-04-13 18:48:28.076 8774] SOCKET_LISTENING: only local
[2019-04-13 18:48:28.076 8774] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2019-04-13 18:48:28.076 8774] MAXDBDAYS: max age for stored queries is 365 days
[2019-04-13 18:48:28.076 8774] RESOLVE_IPV6: Resolve IPv6 addresses
[2019-04-13 18:48:28.077 8774] RESOLVE_IPV4: Resolve IPv4 addresses
[2019-04-13 18:48:28.077 8774] DBINTERVAL: saving to DB file every minute
[2019-04-13 18:48:28.077 8774] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-04-13 18:48:28.077 8774] MAXLOGAGE: Importing up to 24.0 hours of log data
[2019-04-13 18:48:28.077 8774] PRIVACYLEVEL: Set to 0
[2019-04-13 18:48:28.077 8774] IGNORE_LOCALHOST: Show queries from localhost
[2019-04-13 18:48:28.077 8774] BLOCKINGMODE: Null IPs for blocked domains
[2019-04-13 18:48:28.078 8774] REGEX_DEBUGMODE: Inactive
[2019-04-13 18:48:28.078 8774] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2019-04-13 18:48:28.078 8774] DBIMPORT: Importing history from database
[2019-04-13 18:48:28.078 8774] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-04-13 18:48:28.078 8774] PORTFILE: Using /var/run/pihole-FTL.port
[2019-04-13 18:48:28.078 8774] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-04-13 18:48:28.079 8774] WHITELISTFILE: Using /etc/pihole/whitelist.txt
[2019-04-13 18:48:28.079 8774] BLACKLISTFILE: Using /etc/pihole/black.list
[2019-04-13 18:48:28.079 8774] GRAVITYFILE: Using /etc/pihole/gravity.list
[2019-04-13 18:48:28.079 8774] REGEXLISTFILE: Using /etc/pihole/regex.list
[2019-04-13 18:48:28.079 8774] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2019-04-13 18:48:28.079 8774] AUDITLISTFILE: Using /etc/pihole/auditlog.list
[2019-04-13 18:48:28.080 8774] Finished config file parsing
[2019-04-13 18:48:28.082 8774] Database successfully initialized
[2019-04-13 18:48:28.083 8774] New forward server: 8.8.4.4 (0/4096)
[2019-04-13 18:48:28.084 8774] New forward server: 8.8.8.8 (1/4096)
[2019-04-13 18:48:28.085 8774] Imported 86 queries from the long-term database
[2019-04-13 18:48:28.086 8774] -> Total DNS queries: 86
[2019-04-13 18:48:28.086 8774] -> Cached DNS queries: 16
[2019-04-13 18:48:28.086 8774] -> Forwarded DNS queries: 68
[2019-04-13 18:48:28.086 8774] -> Exactly blocked DNS queries: 1
[2019-04-13 18:48:28.086 8774] -> Unknown DNS queries: 1
[2019-04-13 18:48:28.086 8774] -> Unique domains: 42
[2019-04-13 18:48:28.086 8774] -> Unique clients: 8
[2019-04-13 18:48:28.087 8774] -> Known forward destinations: 2
[2019-04-13 18:48:28.087 8774] Successfully accessed setupVars.conf
[2019-04-13 18:48:28.094 8774] PID of FTL process: 8774
[2019-04-13 18:48:28.095 8774] Listening on port 4711 for incoming IPv4 telnet connections
[2019-04-13 18:48:28.095 8774] Listening on port 4711 for incoming IPv6 telnet connections
[2019-04-13 18:48:28.096 8774] Listening on Unix socket
Hey, piHole is working again! Thanks!
Can you clue me in on what the issue might have been?
jfb
April 14, 2019, 1:37am
14
It appears that pihole-FTL was having difficulty with this file: /etc/dnsmasq.d/02-ovpn.conf.save
Interesting...that was a backup of a config file I was using for PiVPN. Thought I was being clever saving it in case I needed it again.
Oh well. Again, thank you.
jfb
April 14, 2019, 12:49pm
16
Just save it in a different directory - your home directory, for example.
system
Closed
May 5, 2019, 12:49pm
17
