Pi hole admin to show stats
Lost connection to API and FTL is offline
suxpevrryn
suxpevrryn
A few poblems are showing in the debug log - Pi-Hole does not appear to be listening on the IP address.
Did you intend to use a /8 subnet mask for your network? That's what the Pi IP is on.
[✓] IPv4 address(es) bound to the wlan0 interface:
10.249.157.50/8 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[✓] hananokai.tv is 3.115.199.44 via localhost (127.0.0.1)
[✗] Failed to resolve hananokai.tv via Pi-hole (10.249.157.50)
[✓] doubleclick.com is 172.217.3.238 via a remote, public DNS server (8.8.8.8)
PIHOLE_INTERFACE=wlan0
IPV4_ADDRESS=10.249.157.50
What is the output of this command from the Pi terminal:
I didn't...
pihole-FTL.service - LSB: pihole-FTL daemon
Active: active (exited) since Fri 2019-11-01 18:38:39 EDT; 25min ago
Process: 4277 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SU
Nov 01 18:38:38 raspberrypi systemd[1]: Starting LSB: pihole-FTL daemon...
Nov 01 18:38:38 raspberrypi pihole-FTL[4277]: Not running
Nov 01 18:38:38 raspberrypi su[4306]: (to pihole) root on none
Nov 01 18:38:38 raspberrypi su[4306]: pam_unix(su:session): session opened for u
Nov 01 18:38:39 raspberrypi pihole-FTL[4277]: dnsmasq: failed to create listenin
Nov 01 18:38:39 raspberrypi su[4306]: pam_unix(su:session): session closed for u
Nov 01 18:38:39 raspberrypi systemd[1]: Started LSB: pihole-FTL daemon.
This typically indicates a port conflict problem. What is the output of the following command from the Pi terminal:
sudo netstat -nltup | grep 'Proto\|:53 \|:5053 \|:5353 \|:8953 \|:67 \|:80 \|:471'
When you post the reply, ensure you don't cut off the right side of the reply. You can format it as pre-formatted text with this command tool on the reply window:
That come in correctly?
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 507/lighttpd
tcp 0 0 127.0.0.1:53 0.0.0.0:* LISTEN 525/unbound
tcp6 0 0 :::80 :::* LISTEN 507/lighttpd
tcp6 0 0 ::1:53 :::* LISTEN 525/unbound
udp 0 0 224.0.0.251:5353 0.0.0.0:* 1014/chromium-brows
udp 0 0 224.0.0.251:5353 0.0.0.0:* 953/libpepflashplay
udp 0 0 0.0.0.0:5353 0.0.0.0:* 371/avahi-daemon: r
udp 0 0 127.0.0.1:53 0.0.0.0:* 525/unbound
udp6 0 0 :::5353 :::* 371/avahi-daemon: r
udp6 0 0 ::1:53 :::* 525/unbound
Yes, it did, and the line above shows the problem. You have unbound listening on port 53, which does not allow pihole-FTL to launch on that port.
Unbound needs to be on another port, typically 5353 if you use the Pi-Hole setup guide for unbound:
