My Pi-hole installation (Pi zero 2 W, RaspOS Lite) was running fine (and still appears to be running fine so far as I can tell), but after installing PiVPN with Dynamic DNS (I have not done the port forwarding step on my router yet) I have lost access to the Pi-hole web interface, yet I can still ssh into my Pi.
I also changed from using WIFI to an ethernet connection.
I disabled WIFI, and changed values in various config files to eth0 (pihole.toml and Wireguard setupVar.conf). But I haven't been able to figure out what has happened. Please help.
New problem now. I am back on the Pi-hole dashboard, but nothing seems to be getting blocked any more.
Before, when watching youtube videos on my ps5, I could see the total queries and queries blocked tally counters going up. They are no longer increasing now.
Has the IP address for Pi-hole functionality now changed to the new address of 192.168.1.127, even though the Pi still has the address of 192.168.1.167 on the router?
I have no idea. But, please note that the best way to set a static IP on your Pi is to do so on the Pi itself. Your router assigns a reserved IP, and you have found this reservation can change.
If the Pi has a static IP configured, it will ignore any IP offered by a DHCP server..
Yes, the problem was that the DNS server address on my router was still directing towards the ...167 address. Although now, I have a new problem in that my router won't let me change to the ...127 address.
When I input the new address, the "configuration has been applied" notification pops up, but the input field instantly clears and goes back to a blank value.
I think I might have to contact my router manufacturer about this one.
