hi,
When pihole logrotate script run,i took an error.The logrotate script is;
root@xxx:/etc/cron.d# more pihole
# Updates ad sources every week
# This file is under source-control of the Pi-hole installation and update
# scripts, any changes made to this file will be overwritten when the softare
# is updated or re-installed. Please make any changes to the appropriate crontab
# or other cron file snippets.
# Pi-hole: Update the ad sources once a week on Sunday at a random time in the
# early morning. Download any updates from the adlists
# Squash output to log, then splat the log to stdout on error to allow for
# standard crontab job error handling.
2 4 * * 7 root PATH="$PATH:/usr/local/bin/" pihole updateGravity >/var/log/pihole_updateGravity.log || cat /var/log/pi
# Pi-hole: Flush the log daily at 00:00
# The flush script will use logrotate if available
# parameter "once": logrotate only once (default is twice)
# parameter "quiet": don't print messages
**49 08 * * * root PATH="$PATH:/usr/local/bin/" pihole flush once quiet**
# Pi-hole: Grab local version and branch every 10 minutes
30 13 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker local
# Pi-hole: Grab remote version every 24 hours
45 14 * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
the problem is
when was this command run,i took an error.tihs syslog look like;
Nov 25 08:49:01 xx cron[1001]: (systempihole) RELOAD (/etc/cron.d/pihole)
Nov 25 08:49:01 xx cron[1001]: Error: bad username; while reading /etc/cron.d/pihole
Nov 25 08:49:01xx cron[1001]: (systempihole) ERROR (Syntax error, this crontab file will be ignored)
No permission problem ;
root@xx:/etc/cron.d# ls -l
total 20
-rw-r--r-- 1 root root 285 May 29 2017 anacron
-rw-r--r-- 1 root root 589 Oca 30 2019 mdadm
-rw-r--r-- 1 root root 712 Oca 18 2018 php
-rw-r--r-- 1 root root 1706 Kas 25 08:57 pihole
Other scripts are no problem,they are runnning.But this script isnt.
Can you help me ?
