lighttpd stays working. I should be able to access the webinterface
lighthttpd keeps crashing after a few hours/days
77a5kiaah4
in the lighttpd-errorlog i just see this line 5 times. Nothing else for today. (log.c.217) server started
(I did not start the server!)
Yes i searched for this problem but none of the past topics actually helped.
i can manually restart the lighttpd service. Works great for a few hours or days until it crahes again. pihole -r also fixes the problem (for a few days)
found)...done.
Reading symbols from /lib/arm-linux-gnueabihf/libcrypt.so.1...Reading symbols from /usr/lib/debug/.build-id/4d/2d9e5f11ccd501ed8b97dd7ceb996b3d5f2151.debug...done.
done.
Reading symbols from /lib/arm-linux-gnueabihf/libnss_compat.so.2...Reading symbols from /usr/lib/debug/.build-id/ce/dbcd6d60886d8865ee06d296477d9415930370.debug...done.
done.
Reading symbols from /lib/arm-linux-gnueabihf/libnsl.so.1...Reading symbols from /usr/lib/debug/.build-id/1a/2613e65d83eeb6c9b4d094b61147e71785eb91.debug...done.
done.
Reading symbols from /lib/arm-linux-gnueabihf/libnss_nis.so.2...Reading symbols from /usr/lib/debug/.build-id/3d/260a6fb5900f371df6d57793400baa4fb1743d.debug...done.
done.
Reading symbols from /lib/arm-linux-gnueabihf/libnss_files.so.2...Reading symbols from /usr/lib/debug/.build-id/7a/6115033566651baedfef4b75b4a49142ae13c6.debug...done.
done.
0x76b9b26c in epoll_wait () at ../sysdeps/unix/syscall-template.S:84
84 ../sysdeps/unix/syscall-template.S: No such file or directory.
(gdb) handle SIGHUP nostop SIGPIPE nostop
Signal Stop Print Pass to program Description
SIGHUP No Yes Yes Hangup
SIGPIPE No Yes Yes Broken pipe
(gdb) continue
Continuing.
Program received signal SIGPIPE, Broken pipe.
Program received signal SIGSEGV, Segmentation fault.
0x0003495c in connection_handle_read_post_state ()
(gdb) backtrace
#0 0x0003495c in connection_handle_read_post_state ()
#1 0x767a1424 in ?? () from /usr/lib/lighttpd/mod_fastcgi.so
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
(gdb)
