I noticed I could no longer connect to the admin page. The last time I connected was when I updated. I added the port I have always used (8093) in the etc\lighttpd\external.conf. When that did not work I changed it in etc\lighttpd\lighttpd.conf. That doesn't do the trick as well. Pi hole is working, but I cannot access it. Apache is running port 80 btw, but I assumed changing the admin port of pi-hole to 8093 would fix that problem. I am at the end of my very limited knowledge...
thx for any help.
What URL are you using to access the web interface?
You do have lighttpd configured on port 8093, per your debug log, in file /etc/lighttpd/lighttpd.conf. But, the debug log is also showing it running on port 80.
What are the contents of /etc/lighttpd/external.conf
I'm using http://192.168.8.156:8093/admin/ a bookmark i'm using some years. I have some other things running there (Domoticz) and I have no problem accessing that (port 8080).
/etc/lighttpd/external.conf contains only one line:
@jfb ; Correct, I forgot that I disable Apache to see if that was a problem. I reenabled it again. @Mcat12 ; Ok, I removed that line from external.conf (it is empty again) and changed the port number to 8093 in lighttpb.conf
I rebooted after those changes, and it is working again. I don't understand it, but I'm happy. Thank you for your responses.
