[lighttpd should start and web interface should be reachable]
[pi.hole/admin give ERR_CONNECTION_REFUSED and found lighttpd failed to start (Process: 5303 ExecStart=/usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf (code=exited, status=255))]
May 13 16:15:22 orangepilite systemd[1]: lighttpd.service: Failed with result 'exit-code'.
May 13 16:15:23 orangepilite systemd[1]: lighttpd.service: Service hold-off time over, scheduling restart.
May 13 16:15:23 orangepilite systemd[1]: Stopped Lighttpd Daemon.
May 13 16:15:23 orangepilite systemd[1]: lighttpd.service: Start request repeated too quickly.
May 13 16:15:23 orangepilite systemd[1]: Failed to start Lighttpd Daemon.
May 13 16:15:23 orangepilite systemd[1]: lighttpd.service: Unit entered failed state.
May 13 16:15:23 orangepilite systemd[1]: lighttpd.service: Failed with result 'exit-code'.
You'll have to resolve that error in order for things to operate. That directory is not one that we control with Pi-hole so we'll be unable to assist you with it.
error.log say server stopped by UID = 0 PID = 0 maybe it's due to root user? btw i've messed a few things i'll later try a full fresh install of armbian
Oooook actually lighttpd don't like to run under root user, made new user, made it sudoers and now works like a charm but i don't know why it's not uploading the debug
yup, i've sad it's all working, Router DHCP server gives all client the orangepilite(where pihole is installed) ip as dns, then pihole use google dns. Orangepilite it's connected to internet and can resolve domains, i've also setted back to the default router dns but stil there's an error while uploading the debug log
here is the debug log if you wanna check, Pi Hole v4.3 Debug Log - Pastebin.com
