Conditional forwarding sends reverse lookups to my OpenWRT router on 192.168.0.1 and the dashboard and logfiles display the name of the host instead of the IP.
Conditional forward is sending the reverse lookups, confirmed through syslog entries by dnsmasq on OpenWRT that show it is returning DNS names, but they are not appearing in the dashboard or history.
https://tricorder.pi-hole.net/7pg2f8aedr!
I recently upgraded my Dockerhub container to the latest version ( Pi-hole Version v4.2.2 Web Interface Version v4.2 FTL Version v4.2.3) and also switched to host networking mode for docker. I do not use pi-hole for DHCP service. The only changes to my docker configuration were that I removed the "--dns=127.0.0.1 --dns=1.1.1.1" line to set dns resolvers and a "--net=host".
For the most part things are working, except none of the hostnames are showing up in the log. I checked my router and I see the reverse lookups coming in and getting resolved into the .lan hostnames, but I do not see the hostnames in the pi-hole dashboard or log. Does anyone have any idea what might be going on? This worked before the upgrade and now I only see the IP addresses.
