Currently the display count for DHCP list of clients is set to 5 and seems to always go back to that setting, Can I set it and keep the default to higher number?
When you change this value, it is stored on the browser localStorage
This value should be persistent, unless you set the browser to remove all data on close.
Also, the value is set individually for each table (you can set 5 on one table and 25 on another).
Thanks for the info. I'll check on when it is persistent. I clear my cache/cookies once in awhile, so maybe that is where I'm seeing it reset etc.
