This should get stubby installed.
The code after sudo nano goes inside the stubby.service you just created.
Follow this guide I just typed. The one I linked doesn't build stubby with SSL from some reason. That's a big problem. Just let me know if you get stuck. Once the above is completed. Run sudo nano /etc/stubby.yml I recommended turning off round robin in there. You may have to enable DNSSEC cannot remember the default. You can change the other configurations to your liking. The last thing you have to do is add the stubby IP and port to the DNS section in http://pi.hole/ this is configured in the above stubby.yml
Lastly I'm on mobile rn sorry if formatting is crap
Be careful with .yml files they do not like whitespace
pi@pi-hole:~ $ cat /etc/unbound/unbound.conf
# Unbound configuration file for Debian.
# See the unbound.conf(5) man page.
# See /usr/share/doc/unbound/examples/unbound.conf for a commented
# reference config file.
# The following line includes additional configuration files from the
# /etc/unbound/unbound.conf.d directory.
include: "/etc/unbound/unbound.conf.d/*.conf"
#use ca-certificate
tls-cert-bundle: "/etc/ssl/certs/ca-certificates.crt"
forward-zone:
forward-addr: 1.1.1.1@853#cloudflare-dns.com
forward-addr: 1.0.0.1@853#cloudflare-dns.com
forward-ssl-upstream: yes
I am giving the answers.
My unbound pihole.conf contains server: at the top with the SSL cert entry underneath.
I removed ssl-cert-bundle from the main unbound config
The certificate file is located at /etc/ssl/certs/ca-certificate.crt
Hence me declaring it there.
If i forward my request in TLS and my upstream is using dnssec how could tampering occur? No one can pretend to be my upstream and my upstream cannot spoof the test. So where is the danger?
I won't be able to ssh in for a bit but I can search for what I have installed. Sometime tonight
In the meantime if you're willing you can post the options it might spark a memory
