I have had pi hole running a while on my rpi with standard os. How do i enable ipv6 as it seems my isp is providing a link now so how do i check ether from Ubuntu or Raspbian
I couldn’t access the attached debugging log probably problem with my account, but anyway you can run pihole -r from the command terminal on the Pi-Hole host, and select the reconfiguration option
This will start the configuration again and then you can select the choice of enabling the ipv6
Sorry for the late reply, It says IPv6 Supported@codinghorror and i can see my ipv6 address and my ipv4 address. But logging into pi.hole does not show an ip address in ipv6 section of the settings area in Network Information
I Have run that command no joy, Its almost as if I need to change the network interface file which I think are deprecated now so no idea what files to start poking at...
