Access to internet is constant and does not require restart or interaction
Internet access can last from a matter of minutes to a number of hours before IP address no longer allocated or internet access not possible.
More information:
My pihole works intermittently throughout the day, even if I did not change any settings on it. When it is not working no connected devices can access the internet or the admin page. I can however access it via SSH and the admin page through the VPN. Pihole is running on a raspberry pi zero w.
I have a ubiquiti access point that most devices connect to wirelessly. This is wired into the router which has DHCP turned off. The Raspberry pi connects to the router wirelessly.
Often performing a restart of the pi gets everything working again. Sometimes it needs the power pulling out and putting back in again, sometimes more than once.
This is the debug log which I took when it was not working, but I could still access it via ssh. https://tricorder.pi-hole.net/f72buvd6e0!
Any help would be great. Thanks
