Is it possible to install Pi-Hole on PIVOS XIOS DS device? It's android/linux based. It's like a Raspberry Pi lookalike.
Thanks
Thanks
Does it run Debian/Ubuntu, or have access to the repositories via apt-get
It can run on Ubuntu I think and Repositories via apt-get yes.
Then it may be possible to run the Pi-hole on it. None of us have one, so we can't tell for sure if it will work, so give it a try.
Thanks. I will give it a try and let you know.
