- I have two network interfaces in the system I installed it in. eth0, which is static, and tun0, which is DHCP because it's a VPN. Obviously I wanted the script to listen on eth0. When I selected that during the install script it insisted on setting an IP(ok, thanks?), then detected the ip of TUN0 and suggested that be used. I aborted the script, re-ran it, told it to use TUN0 and to set it to it's current static, then had to go back and remove the static configuration it had made. Of course I then had to edit the dnsmasq file to tell it to listen on the proper interface.
Perhaps presuming anyone definitely wants their network configuration adjusted by the installation script is over-reaching and it should be something one can opt out of?
