Are you able to access 10.0.0.219? What does dig or nslookuppi.hole show as the IP address?
lighttpd is working correcly:
[✓] udp:0.0.0.0:53 is in use by pihole-FTL
[✓] udp:[::]:53 is in use by pihole-FTL
[✓] tcp:0.0.0.0:53 is in use by pihole-FTL
[✓] tcp:127.0.0.1:4711 is in use by pihole-FTL
[✓] tcp:0.0.0.0:80 is in use by lighttpd
[✓] tcp:[::]:53 is in use by pihole-FTL
[✓] tcp:[::1]:4711 is in use by pihole-FTL
[✓] tcp:[::]:80 is in use by lighttpd
[✓] lighttpd daemon is active
*** [ DIAGNOSING ]: Lighttpd configuration test
[✓] No error in lighttpd configuration
*** [ DIAGNOSING ]: Dashboard headers
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
Do you have a setting in your browser which forces all http requests to become https requests? If so, turn it off or find where you can make an exception for pi.hole or 10.0.0.219.
For example in Firefox this is in Settings and called "HTTPS-Only Mode" and you can turn it off or turn it on but add exceptions.
