Hello,
I tried to install pihole on a raspberry, but instead of starting pihole the installation stops with following messages. What went wrong?
root@raspberrypi:/# curl -sSL https://install.pi-hole.net | sudo bash
stty: standard input: Inappropriate ioctl for device
[���] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[���] Disk space check
[���] Update local cache of available packages
[���] Checking apt-get for upgraded packages... up to date!
[���] Checking for apt-utils
[���] Checking for dialog
[���] Checking for debconf
[���] Checking for dhcpcd5
[���] Checking for git
[���] Checking for iproute
[���] Checking for whiptail
[i] Using [i] Static IP already configured
[i] IPv4 address: 192.168.1.120/24
[i] IPv6 address:
[i] Web Interface On
[i] Web Server On
[i] Logging On.
[���] Check for existing repository in /etc/.pihole
[���] Clone https://github.com/pi-hole/pi-hole.git into /etc/.pihole
[���] Check for existing repository in /var/www/html/admin
[���] Update repo in /var/www/html/admin
[i] Main Dependency checks...
[i] Checking for bc (will be installed)
[���] Checking for cron
[���] Checking for curl
[i] Checking for dnsutils (will be installed)
[���] Checking for iputils-ping
[i] Checking for lsof (will be installed)
[i] Checking for netcat (will be installed)
[���] Checking for psmisc
[���] Checking for sudo
[���] Checking for unzip
[���] Checking for wget
[i] Checking for idn2 (will be installed)
[i] Checking for sqlite3 (will be installed)
[���] Checking for libcap2-bin
[i] Checking for dns-root-data (will be installed)
[i] Checking for resolvconf (will be installed)
[i] Checking for lighttpd (will be installed)
[i] Checking for php5-common (will be installed)
[i] Checking for php5-cgi (will be installed)
[i] Checking for php5-sqlite (will be installed)
root@raspberrypi:/# pi.hole/admin
bash: pi.hole/admin: No such file or directory
root@raspberrypi:/# pihole -r
bash: pihole: command not found
root@raspberrypi:/# cd /etc/.pihole
root@raspberrypi:/etc/.pihole# sudo git status
On branch master
nothing to commit (working directory clean)
root@raspberrypi:/etc/.pihole# pihole -r
Thank you
