Please ensure that you are running the latest version of the beta code. Run pihole -up to update to the latest, then verify that the problem still exists before reporting it.
Problem with Beta 5.0:
When I open the new whitelist, blacklist or group management adlists page, the browser's console says <input id="comment class="form-control" is not-unique.
But there must not exist multiple elements with the same id value in the document.
They should be enumerated or set as class values instead.
In contrast to ids, classes may occur several times in the document.
Thanks for reporting this. I have never learned to code Javascript and the uniqueness of ids is actually new to me. Interestingly enough, Firefox has never shown this kind of warning to me.
Could you check if I found them all and maybe if I didn't break anything as well?
Yeah, go ahead! I can use any support in the beta code. I'm currently looking at a more subtle problem with FTL and internal name resolution and it's good if I can invest all my spare time into this problem.
I don't know if this has something to do with the topic actually, but i just found:
Version status (pihole -v):
Pi-hole version is v4.3.2-419-gee7090b (Latest: v4.3.2)
AdminLTE version is v4.3.2-424-ge169bec (Latest: v4.3.3)
FTL version is vDev-ff840d0 (Latest: v4.3.1)
(updated this morning and received only one for AdminLTE)
The issue: The WebIF seems working normally, but a click on Domains in Group Management produces a line with a combined error message in lightpd's error log:
(mod_fastcgi.c.421) FastCGI-stderr: PHP message: PHP Notice: Undefined index: type in /var/www/html/admin/scripts/pi-hole/php/header.php on line 433PHP message: PHP Notice: Undefined index: type in /var/www/html/admin/scripts/pi-hole/php/header.php on line 437
To fix this, type needs first be checked whether it is set (with isset($_GET['type'])
or a default value must be specified (with $_GET['type'] ?? "") in that lines.
Ah, yes. I forgot about this, thanks for checking. Could you just add this with your proposed PR? It's hardly a change that requires a dedicate PR if you're anyway going to open another one.
