from the terminal I do a sudo -i
I did both the apt-get upgrade and the apt-get dist-upgrade
I run the curl command and I get the installer that asks me all of the pihole questions. I answer all of them and it exits.
On the terminal I see:
[i] Using Google DNS servers
[i] Static IP already configured
[i] IPv4 address: 192.168.124.250/24
[i] IPv6 address:
[i] Web Interface On
[i] Web Server On
[i] Logging On.
[✓] Check for existing repository in /etc/.pihole
[✓] Update repo in /etc/.pihole
[✓] Check for existing repository in /var/www/html/admin
[✓] Update repo in /var/www/html/admin
[i] Main Dependency checks...
[✓] Checking for cron
[✓] Checking for curl
[i] Checking for dnsutils (will be installed)
[✓] Checking for iputils-ping
[i] Checking for lsof (will be installed)
[i] Checking for netcat (will be installed)
[✓] Checking for psmisc
[✓] Checking for sudo
[✓] Checking for unzip
[✓] Checking for wget
[i] Checking for idn2 (will be installed)
[i] Checking for sqlite3 (will be installed)
[i] Checking for libcap2-bin (will be installed)
[i] Checking for dns-root-data (will be installed)
[i] Checking for resolvconf (will be installed)
[✓] Checking for libcap2
[i] Checking for lighttpd (will be installed)
[i] Checking for php5-common (will be installed)
[i] Checking for php5-cgi (will be installed)
[i] Checking for php5-sqlite (will be installed)
A second installer screens shows up and exits and I'm back to the terminal prompt.
The only file in /etc/pihole is adlists.lists
there is no .pihole file
pihole command is not found
OS Version is wheezy/sid
There is 1/2 of a 16Gb card in the pi.
Thanks for any extra help
