here is small limited fake represented data from win2008 dns & dhcp exported lists, that if possible, i would like to import into pihole. i'm dropping domain and win systems as you know.
@melvinkitnick listed some good ideas i think.
[dns exported cvs data]
Name,Type,Data,Timestamp,,
(same as parent folder),Start of Authority (SOA),[25269], winDC1.home.com., administrator.home.com.,static
(same as parent folder),WINS Lookup,[192.168.1.100] ,static,,
(same as parent folder),Name Server (NS),winDC2.home.com.,static,,
(same as parent folder),Name Server (NS),winDC1.home.com.,static,,
(same as parent folder),Host (A),192.168.1.101,?2/?20/?2022 7:00:00 AM,,
(same as parent folder),Host (A),192.168.1.100,?2/?28/?2022 9:00:00 AM,,
_msdcs,,,,,
_sites,,,,,
_tcp,,,,,
_udp,,,,,
comp1,Host (A),192.168.1.21,,,static
comp2,Host (A),192.168.1.22,,,static
comp3,Host (A),192.168.1.23,,,
DomainDnsZones,,,,,
comp4,Host (A),192.168.1.24,,,static
comp5,Host (A),192.168.1.25,,,static
gw,Host (A),192.168.1.1,,,static
ForestDnsZones,,,,,
printer,Host (A),192.168.1.35,,,static
switch1,Host (A),192.168.1.11,,,static
switch2,Host (A),192.168.1.12,,,static
switch3,Host (A),192.168.1.13,,,static
winDC1,Host (A),192.168.1.100,,,static
winDC2,Host (A),192.168.1.101,,,static
rpi-pihole1,Host (A),192.168.1.201,,,static
rpi-pihole2,Host (A),192.168.1.202,,,static
rpi-pihole3,Host (A),192.168.1.203,,,static
[dhcp exported cvs data]
Client IP Address,Name,Lease Expiration,Type,Unique ID,Description,Network Access Protection,Probation Expiration,Filter Profile
192.168.1.21,comp1.home.com,Reservation (active),DHCP,,,Full Access,,
192.168.1.22,comp2.home.com,Reservation (active),DHCP,,,Full Access,,
192.168.1.23,comp3.home.com,Reservation (active),DHCP,,,Full Access,,
192.168.1.24,comp4.home.com,Reservation (active),DHCP,,,Full Access,,
192.168.1.25,comp5.home.com,Reservation (active),DHCP,,,Full Access,,
192.168.1.1,gw.home.com,Reservation (active),DHCP,,,Full Access,,
192.168.1.35,printer.home.com,Reservation (active),DHCP,,,Full Access,,
192.168.1.11,switch1.home.com,Reservation (active),DHCP,,,Full Access,,
192.168.1.12,switch2.home.com,Reservation (active),DHCP,,,Full Access,,
192.168.1.13,switch3.home.com,Reservation (active),DHCP,,,Full Access,,
192.168.1.100,winDC1.home.com,Reservation (active),DHCP,,,Full Access,,
192.168.1.101,winDC2.home.com,Reservation (active),DHCP,,,Full Access,,
192.168.1.201,rpi-pihole1.home.com,Reservation (active),DHCP,,,Full Access,,
192.168.1.202,rpi-pihole2.home.com,Reservation (active),DHCP,,,Full Access,,
192.168.1.203,rpi-pihole3.home.com,Reservation (active),DHCP,,,Full Access,,
