Pi 3+ - login via SSH
ssh to ip address. Not sure of user name, but enter the password that works on the web admin interface. Can't determine what user name should be
https://tricorder.pi-hole.net/m0ql97naux
jfb
2
The credentials to ssh into the Pi terminal are different than the Pi-hole web admin credentials.
For Raspbian OS (which you are running), the default user is pi and the login password is raspberry.
Thanks, jfb. Apparently, I didn't properly document the password change that I was prompted to change.
I just re-installed the OS image, and then pi-hole, from scratch.
Many thanks for the help.
system
Closed
4
