Hi everyone,
I expected to have internet on my pi hole raspberry pi
No internet on my pi. I try to ping 8.8.8.8 as follows
$ ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 54(84) bytes of data
Nothing else happend. This might be some sort of dns loop with my router.
I've got no internet to post the result, so here it is:
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations. This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected. Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2019-06-08:16:24:04 debug log has been initialized.
[✓] Core:
[i] Branch: master
[i] Commit: b3898b9
[✓] Web:
[i] Branch: master
[i] Commit: 8f3ed41
[✓] FTL: v4.2.3 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] 1.4.45
[i] 7.0.33
[✓] Raspbian GNU/Linux 9 (stretch)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
[✓] armv6l
192.168.0.109/24 matches the IP found in /etc/pihole/setupVars.conf
fe80::de25:1bb9:a500:d9e9 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[i] Default IPv4 gateway: 192.168.0.1
* Pinging 192.168.0.1...
[*:80] is in use by lighttpd
[*:53] is in use by pihole-FTL
[127.0.0.1:4711] is in use by pihole-FTL
[[::1]:4711] is in use by pihole-FTL
[✓] atropismlsuttxa.download is 0.0.0.0 via localhost (127.0.0.1)
[✓] atropismlsuttxa.download is 0.0.0.0 via Pi-hole (192.168.0.109)
[✓] lighttpd daemon is active
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=192.168.0.109/24
IPV6_ADDRESS=
PIHOLE_DNS_1=1.1.1.1
PIHOLE_DNS_2=1.0.0.1
QUERY_LOGGING=true
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=true
BLOCKING_ENABLED=true
DHCP_START=192.168.0.201
DHCP_END=192.168.0.251
DHCP_ROUTER=192.168.0.1
DHCP_LEASETIME=24
PIHOLE_DOMAIN=lan
DHCP_IPv6=false
DHCP_rapid_commit=false
DHCP_ACTIVE=false
[✓] Block page X-Header: X-Pi-hole: A black hole for Internet advertisements.
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
-rw-r--r-- 1 root root 2647511 juin 2 03:24 /etc/pihole/gravity.list
0.0.0.0
0.nextyourcontent.com
0.r.msn.com
0.start.bz
zzz.clickbank.net
zzzezeroe.fr
zzzpooeaz-france.com
zzzrtrcm2.com
-rw-r--r-- 1 root root 381 mai 11 14:44 /etc/pihole/adlists.list
-rw-r--r-- 1 root root 48 juin 2 03:24 /etc/pihole/local.list
192.168.0.109 raspberrypi
192.168.0.109 pi.hole
-rw-r--r-- 1 root root 234 mai 11 14:53 /etc/pihole/logrotate
/var/log/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-r--r-- 1 root root 1515 juin 2 17:50 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries
local-ttl=2
log-async
server=1.1.1.1
server=1.0.0.1
interface=eth0
-rw-r--r-- 1 root root 3102 mai 11 14:53 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "pihole/index.php"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
"X-Frame-Options" => "DENY"
$HTTP["url"] =~ ".ttf$" {
url.access-deny = ("")
-rw-r--r-- 1 root root 1703 mai 11 14:53 /etc/cron.d/pihole
20 3 * * 7 root PATH="$PATH:/usr/local/bin/" pihole updateGravity >/var/log/pihole_updateGravity.log || cat /var/log/pihole_updateGravity.log
00 00 * * * root PATH="$PATH:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker local
8 19 * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 5003 juin 8 16:27 /var/log/lighttpd/error.log
2019-06-02 06:25:11: (server.c.1534) logfiles cycled UID = 0 PID = 8961
2019-06-02 16:53:26: (server.c.1828) server stopped by UID = 0 PID = 1
2019-06-02 16:53:55: (log.c.217) server started
2019-06-02 16:53:55: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2019-06-02 16:54:35: (server.c.1828) server stopped by UID = 0 PID = 1
2019-06-02 16:55:03: (log.c.217) server started
2019-06-02 16:55:03: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2019-06-02 16:56:10: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 58
2019-06-02 17:42:52: (server.c.1828) server stopped by UID = 0 PID = 1
2019-06-02 17:43:20: (log.c.217) server started
2019-06-02 17:43:20: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2019-06-02 17:51:16: (server.c.1828) server stopped by UID = 0 PID = 1
2019-06-02 17:51:45: (log.c.217) server started
2019-06-02 17:51:45: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2019-06-02 17:52:47: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined offset: 1 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 57
2019-06-02 17:52:47: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 58
2019-06-02 17:53:00: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 58
2019-06-02 18:14:48: (server.c.1828) server stopped by UID = 0 PID = 1
2019-06-02 18:15:16: (log.c.217) server started
2019-06-02 18:15:16: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2019-06-02 18:16:01: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined offset: 1 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 57
2019-06-02 18:16:01: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 58
2019-06-02 18:16:30: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 58
2019-06-02 18:16:32: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 58
2019-06-02 18:16:42: (server.c.1828) server stopped by UID = 0 PID = 1
-rw-r--r-- 1 pihole pihole 4041 juin 8 12:08 /var/log/pihole-FTL.log
[2019-06-08 12:07:15.180 655] Shutting down...
[2019-06-08 12:07:15.298 655] Finished final database update
[2019-06-08 12:07:15.302 655] ########## FTL terminated after 496198368.0 ms! ##########
[2019-06-08 12:07:50.344 609] Using log file /var/log/pihole-FTL.log
[2019-06-08 12:07:50.348 609] ########## FTL started! ##########
[2019-06-08 12:07:50.348 609] FTL branch: master
[2019-06-08 12:07:50.349 609] FTL version: v4.2.3
[2019-06-08 12:07:50.349 609] FTL commit: aae487e
[2019-06-08 12:07:50.349 609] FTL date: 2019-02-25 17:18:14 -0800
[2019-06-08 12:07:50.349 609] FTL user: pihole
[2019-06-08 12:07:50.351 609] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-06-08 12:07:50.352 609] SOCKET_LISTENING: only local
[2019-06-08 12:07:50.352 609] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2019-06-08 12:07:50.352 609] MAXDBDAYS: max age for stored queries is 365 days
[2019-06-08 12:07:50.353 609] RESOLVE_IPV6: Resolve IPv6 addresses
[2019-06-08 12:07:50.353 609] RESOLVE_IPV4: Resolve IPv4 addresses
[2019-06-08 12:07:50.353 609] DBINTERVAL: saving to DB file every minute
[2019-06-08 12:07:50.353 609] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-06-08 12:07:50.354 609] MAXLOGAGE: Importing up to 24.0 hours of log data
[2019-06-08 12:07:50.354 609] PRIVACYLEVEL: Set to 0
[2019-06-08 12:07:50.354 609] IGNORE_LOCALHOST: Show queries from localhost
[2019-06-08 12:07:50.355 609] BLOCKINGMODE: Null IPs for blocked domains
[2019-06-08 12:07:50.355 609] REGEX_DEBUGMODE: Inactive
[2019-06-08 12:07:50.355 609] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2019-06-08 12:07:50.355 609] DBIMPORT: Importing history from database
[2019-06-08 12:07:50.356 609] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-06-08 12:07:50.356 609] PORTFILE: Using /var/run/pihole-FTL.port
[2019-06-08 12:07:50.356 609] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-06-08 12:07:50.356 609] WHITELISTFILE: Using /etc/pihole/whitelist.txt
[2019-06-08 12:07:50.357 609] BLACKLISTFILE: Using /etc/pihole/black.list
[2019-06-08 12:07:50.357 609] GRAVITYFILE: Using /etc/pihole/gravity.list
[2019-06-08 12:07:50.357 609] REGEXLISTFILE: Using /etc/pihole/regex.list
[2019-06-08 12:07:50.357 609] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2019-06-08 12:07:50.358 609] AUDITLISTFILE: Using /etc/pihole/auditlog.list
[2019-06-08 12:07:50.358 609] Finished config file parsing
[2019-06-08 12:07:50.475 609] Database successfully initialized
[2019-06-08 12:07:50.501 609] New forward server: 1.0.0.1 (0/4096)
[2019-06-08 12:07:50.524 609] Resizing "/FTL-strings" from 4096 to 8192
[2019-06-08 12:07:50.579 609] Resizing "/FTL-strings" from 8192 to 12288
[2019-06-08 12:07:50.698 609] Resizing "/FTL-strings" from 12288 to 16384
[2019-06-08 12:07:50.757 609] Imported 3601 queries from the long-term database
[2019-06-08 12:07:50.758 609] -> Total DNS queries: 3601
[2019-06-08 12:07:50.758 609] -> Cached DNS queries: 2
[2019-06-08 12:07:50.759 609] -> Forwarded DNS queries: 3069
[2019-06-08 12:07:50.759 609] -> Exactly blocked DNS queries: 530
[2019-06-08 12:07:50.759 609] -> Unknown DNS queries: 0
[2019-06-08 12:07:50.759 609] -> Unique domains: 495
[2019-06-08 12:07:50.759 609] -> Unique clients: 4
[2019-06-08 12:07:50.760 609] -> Known forward destinations: 1
[2019-06-08 12:07:50.760 609] Successfully accessed setupVars.conf
[2019-06-08 12:07:50.831 621] PID of FTL process: 621
[2019-06-08 12:07:50.837 621] Listening on port 4711 for incoming IPv4 telnet connections
[2019-06-08 12:07:50.838 621] Listening on port 4711 for incoming IPv6 telnet connections
[2019-06-08 12:07:50.838 621] Listening on Unix socket
[2019-06-08 12:07:50.860 621] INFO: No whitelist file found
[2019-06-08 12:07:50.860 621] Compiled 0 Regex filters and 0 whitelisted domains in 0.6 msec (0 errors)
[2019-06-08 12:07:57.296 621] /etc/pihole/gravity.list: parsed 113192 domains (took 6417.8 ms)
[2019-06-08 12:08:05.505 621] New forward server: 1.1.1.1 (1/4096)
*** [ DIAGNOSING ]: contents of /dev/shm
-rw------- 1 pihole pihole 2621440 juin 8 12:07 /dev/shm/FTL-clients
-rw------- 1 pihole pihole 108 juin 8 12:07 /dev/shm/FTL-counters
-rw------- 1 pihole pihole 131072 juin 8 14:08 /dev/shm/FTL-domains
-rw------- 1 pihole pihole 163840 juin 8 12:07 /dev/shm/FTL-forwarded
-rw------- 1 pihole pihole 28 juin 8 12:07 /dev/shm/FTL-lock
-rw------- 1 pihole pihole 8192 juin 8 12:07 /dev/shm/FTL-overTime
-rw------- 1 pihole pihole 229376 juin 8 12:59 /dev/shm/FTL-queries
-rw------- 1 pihole pihole 12 juin 8 12:07 /dev/shm/FTL-settings
-rw------- 1 pihole pihole 16384 juin 8 12:07 /dev/shm/FTL-strings
*** [ DIAGNOSING ]: Locale
LANG=fr_FR.UTF-8
-rw-r--r-- 1 pihole pihole 580688 juin 8 16:27 /var/log/pihole.log
-----head of pihole.log------
Jun 8 00:00:05 dnsmasq[655]: query[PTR] 102.0.168.192.in-addr.arpa from 127.0.0.1
Jun 8 00:00:05 dnsmasq[655]: forwarded 102.0.168.192.in-addr.arpa to 1.0.0.1
Jun 8 00:00:05 dnsmasq[655]: forwarded 102.0.168.192.in-addr.arpa to 1.1.1.1
Jun 8 00:00:10 dnsmasq[655]: query[PTR] 103.0.168.192.in-addr.arpa from 127.0.0.1
Jun 8 00:00:10 dnsmasq[655]: forwarded 103.0.168.192.in-addr.arpa to 1.0.0.1
Jun 8 00:00:10 dnsmasq[655]: forwarded 103.0.168.192.in-addr.arpa to 1.1.1.1
Jun 8 00:00:15 dnsmasq[655]: query[PTR] 103.0.168.192.in-addr.arpa from 127.0.0.1
Jun 8 00:00:15 dnsmasq[655]: forwarded 103.0.168.192.in-addr.arpa to 1.0.0.1
Jun 8 00:00:15 dnsmasq[655]: forwarded 103.0.168.192.in-addr.arpa to 1.1.1.1
Jun 8 00:00:20 dnsmasq[655]: query[PTR] 202.0.168.192.in-addr.arpa from 127.0.0.1
Jun 8 00:00:20 dnsmasq[655]: forwarded 202.0.168.192.in-addr.arpa to 1.0.0.1
Jun 8 00:00:20 dnsmasq[655]: forwarded 202.0.168.192.in-addr.arpa to 1.1.1.1
Jun 8 00:00:25 dnsmasq[655]: query[PTR] 202.0.168.192.in-addr.arpa from 127.0.0.1
Jun 8 00:00:25 dnsmasq[655]: forwarded 202.0.168.192.in-addr.arpa to 1.0.0.1
Jun 8 00:00:25 dnsmasq[655]: forwarded 202.0.168.192.in-addr.arpa to 1.1.1.1
Jun 8 00:00:30 dnsmasq[655]: query[PTR] 231.0.168.192.in-addr.arpa from 127.0.0.1
Jun 8 00:00:30 dnsmasq[655]: forwarded 231.0.168.192.in-addr.arpa to 1.0.0.1
Jun 8 00:00:30 dnsmasq[655]: forwarded 231.0.168.192.in-addr.arpa to 1.1.1.1
Jun 8 00:00:35 dnsmasq[655]: query[PTR] 231.0.168.192.in-addr.arpa from 127.0.0.1
Jun 8 00:00:35 dnsmasq[655]: forwarded 231.0.168.192.in-addr.arpa to 1.0.0.1
[✓] ** FINISHED DEBUGGING! **
* For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
* If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
* Log will NOT be uploaded to tricorder.
