[I have a problem to install unbound. I followed the guide from wiki step by step Redirecting...]
journalctl -u unbound
-- Logs begin at Wed 2018-10-31 16:58:48 CST, end at Wed 2018-10-31 17:46:39 CST. --
Oct 31 17:10:02 dns systemd[1]: Starting Unbound DNS server...
Oct 31 17:10:02 dns package-helper[10966]: /var/lib/unbound/root.key does not exist, copying from /usr/share/dns/root.key
Oct 31 17:10:03 dns package-helper[10966]: /var/lib/unbound/root.key has content
Oct 31 17:10:03 dns package-helper[10966]: success: the anchor is ok
Oct 31 17:10:03 dns unbound[10971]: [1540977003] unbound[10971:0] error: can't bind socket: Address already in use for ::1
Oct 31 17:10:03 dns unbound[10971]: [1540977003] unbound[10971:0] fatal error: could not open ports
Oct 31 17:10:03 dns systemd[1]: **unbound.service: Main process exited, code=exited, status=1/FAILURE**
Oct 31 17:10:03 dns systemd[1]: **unbound.service: Failed with result 'exit-code'.**
Oct 31 17:10:03 dns systemd[1]: **Failed to start Unbound DNS server.**
Oct 31 17:10:03 dns systemd[1]: unbound.service: Service hold-off time over, scheduling restart.
Oct 31 17:10:03 dns systemd[1]: unbound.service: Scheduled restart job, restart counter is at 1.
Oct 31 17:10:03 dns systemd[1]: Stopped Unbound DNS server.
Oct 31 17:10:03 dns systemd[1]: Starting Unbound DNS server...
Oct 31 17:10:04 dns package-helper[11049]: /var/lib/unbound/root.key has content
Oct 31 17:10:04 dns package-helper[11049]: success: the anchor is ok
Oct 31 17:10:04 dns unbound[11145]: [1540977004] unbound[11145:0] error: can't bind socket: Address already in use for ::1
Oct 31 17:10:04 dns unbound[11145]: [1540977004] unbound[11145:0] fatal error: could not open ports
Oct 31 17:10:04 dns systemd[1]: **unbound.service: Main process exited, code=exited, status=1/FAILURE**
Oct 31 17:10:04 dns systemd[1]: **unbound.service: Failed with result 'exit-code'.**
Oct 31 17:10:04 dns systemd[1]: **Failed to start Unbound DNS server.**
Oct 31 17:10:05 dns systemd[1]: unbound.service: Service hold-off time over, scheduling restart.
Oct 31 17:10:05 dns systemd[1]: unbound.service: Scheduled restart job, restart counter is at 2.
Oct 31 17:10:05 dns systemd[1]: Stopped Unbound DNS server.
Oct 31 17:10:05 dns systemd[1]: Starting Unbound DNS server...
Oct 31 17:10:05 dns package-helper[11222]: /var/lib/unbound/root.key has content
Oct 31 17:10:05 dns package-helper[11222]: success: the anchor is ok
Oct 31 17:10:05 dns unbound[11267]: [1540977005] unbound[11267:0] error: can't bind socket: Address already in use for ::1
Oct 31 17:10:05 dns unbound[11267]: [1540977005] unbound[11267:0] fatal error: could not open ports
Oct 31 17:10:05 dns systemd[1]: **unbound.service: Main process exited, code=exited, status=1/FAILURE**
Oct 31 17:10:05 dns systemd[1]: **unbound.service: Failed with result 'exit-code'.**
Oct 31 17:10:05 dns systemd[1]: **Failed to start Unbound DNS server.**
Oct 31 17:10:06 dns systemd[1]: unbound.service: Service hold-off time over, scheduling restart.
Oct 31 17:10:06 dns systemd[1]: unbound.service: Scheduled restart job, restart counter is at 3.
Oct 31 17:10:06 dns systemd[1]: Stopped Unbound DNS server.
Oct 31 17:10:06 dns systemd[1]: Starting Unbound DNS server...
Oct 31 17:10:06 dns package-helper[11337]: /var/lib/unbound/root.key has content
Oct 31 17:10:06 dns package-helper[11337]: success: the anchor is ok
Oct 31 17:10:06 dns unbound[11370]: [1540977006] unbound[11370:0] error: can't bind socket: Address already in use for ::1
Oct 31 17:10:06 dns unbound[11370]: [1540977006] unbound[11370:0] fatal error: could not open ports
Oct 31 17:10:06 dns systemd[1]: **unbound.service: Main process exited, code=exited, status=1/FAILURE**
Oct 31 17:10:06 dns systemd[1]: **unbound.service: Failed with result 'exit-code'.**
Oct 31 17:10:06 dns systemd[1]: **Failed to start Unbound DNS server.**
Oct 31 17:10:07 dns systemd[1]: unbound.service: Service hold-off time over, scheduling restart.
Oct 31 17:10:07 dns systemd[1]: unbound.service: Scheduled restart job, restart counter is at 4.
Oct 31 17:10:07 dns systemd[1]: Stopped Unbound DNS server.]_
server:
logfile: "/var/log/unbound/unbound.log"
verbosity: 0
port: 5353
do-ip4: yes
do-udp: yes
do-tcp: yes
do-ip6: no
root-hints: "/var/lib/unbound/root.hints"
# Trust glue only if it is within the servers authority
harden-glue: yes
harden-dnssec-stripped: yes
use-caps-for-id: no
# Suggested by the unbound man page to reduce fragmentation reassembly problems
edns-buffer-size: 1472
# TTL bounds for cache
cache-min-ttl: 3600
cache-max-ttl: 86400
prefetch: yes
# One thread should be sufficient, can be increased on beefy machines
num-threads: 1
# Ensure kernel buffer is large enough to not loose messages in traffic spikes
so-rcvbuf: 1m
private-address: 10.0.0.0/8
private-address: fd00::/8
private-address: fe80::/10
Once again, force the following optional content to be forced once. Some are normal.
Optional: Download the list of primary root servers (serving the domain .). Unbound ships its own list but we can also download the most recent list and update it whenever we think it is a good idea. Note: there is no point in doing It more often then every 6 months.
