Tried doing a do-release-upgrade on Ubuntu 18
It works
It didn't. DNS would not start
I have reset to the old snapshot so I cannot give a log file.
As I mentioned, I tried going to Ubuntu 20 but that broke pi-hole. DNS would not start. I tried removing /etc/dnsmasq.d/lxd but no dice.
After I reverted to the snapshot, I tried updating pihole with pihole -up but that said Ubuntu 18 was not supported.
So my question is how do I proceed? I believe pihole can be made to ignore the OS constraint. I could try that before upgrading the OS.
Or I could perhaps export and import the config in a clean install?
What is the best way of getting to the latest Ubuntu and pihole at this point?
pihole -v gives me this, byt the way:
pihole -v
fatal: detected dubious ownership in repository at '/etc/.pihole'
To add an exception for this directory, call:
git config --global --add safe.directory /etc/.pihole
Pi-hole version is ERROR (Latest: v5.16.2)
fatal: detected dubious ownership in repository at '/var/www/html/admin'
git config --global --add safe.directory /var/www/html/admin
AdminLTE version is ERROR (Latest: v5.19)
FTL version is v5.16.1 (Latest: v5.22)
