Can you (or someone) please explain - step-by-step - how to update Pi-Hole on Docker without loosing any settings og configs.
Thanks @DanSchaper, I have read this guide earlier. It tells me not to do exactly what I want to do ( pihole -up
), but it fails to explain what will happen if I do.
Step 2b tells exactly why I cannot use the preferred method. So even though I understand the preferred method, it is not an option at this point. So my question is really; Will pihole -up
screw up my installation and leave me in the dark, or is it likely to work (even if it is not recommended) ?
The guide is detailed and explicit on exactly what to do. pihole -up
will not work in docker.
