Hello
How can I stop the Pihole UI version 3.3.1 from insisting on a minimum DNS server?
I setup PiHole to use DNS-over-TLS by hand, using Stubby as a local DNS client. I changed the dnsmasq settings to use Stubby. Unfortunately, I can't switch off the DNS settings in the UI. And it does not allow me to set an alternative port. So now Pihole is making parallel DNS requests to both the settings in my stubby file AND to the stub setting left in the UI (in this case Quad-9), that I can't switch off. I confirmed this with TCPdump. Here are the stubby settings for DNSmasq
egrep -v "^#.*|^$" /etc/dnsmasq.d/02-stubby.conf
server=127.0.2.2#2053
server=0::2#2053
How can I disable the UI settings in Web-UI version 3.3 Pihole version 3.3.1? Or do I just need to specify port 53 in the configs?
Thanks for your help!
Regards
L
