Seriously?
Do you think there should be some fall-back logic when /sys/class/hwmon/hwmon0/temp1_input
is missing?
$ ls /sys/class/hwmon/hwmon?/temp?_input
/sys/class/hwmon/hwmon1/temp1_input /sys/class/hwmon/hwmon4/temp1_input
/sys/class/hwmon/hwmon3/temp1_input /sys/class/hwmon/hwmon4/temp2_input
/sys/class/hwmon/hwmon3/temp2_input /sys/class/hwmon/hwmon4/temp3_input
/sys/class/hwmon/hwmon3/temp3_input /sys/class/hwmon/hwmon4/temp4_input
/sys/class/hwmon/hwmon3/temp4_input /sys/class/hwmon/hwmon4/temp5_input
/sys/class/hwmon/hwmon3/temp5_input /sys/class/hwmon/hwmon5/temp1_input
/sys/class/hwmon/hwmon3/temp6_input
$ lsb_release -d
Description: Ubuntu 20.04.1 LTS
No, I think the whole temperature section needs to be removed. There's no use for it and there's no way to cover all the platforms. It only shows on certain boards and honestly it's useless information.
I agree - you can easily get the temperature from the terminal with a Linux command and there is no real need to have this on the Pi-hole dashboard.
