Im getting this "Maximum number of concurrent DNS queries reached" warning. Im not the most tech savvy person so I was just looking for help changing the max number of DNS queries
debug token: https://tricorder.pi-hole.net/xdV1b3So/
You are running an open resolver. Your Pi-hole is exposed to the internet via port 53.
Close port 53 immediately.
Jan 24 05:15:38 dnsmasq[12943]: forwarded peacecorps.gov to 1.1.1.1
Jan 24 05:15:38 dnsmasq[12943]: query[ANY] peacecorps.gov from 104.7.215.14
Jan 24 05:15:38 dnsmasq[12943]: query[ANY] peacecorps.gov from 75.135.1.15
Jan 24 05:15:38 dnsmasq[12943]: reply error is not implemented
Jan 24 05:15:38 dnsmasq[12943]: query[ANY] peacecorps.gov from 24.70.148.48
Jan 24 05:15:38 dnsmasq[12943]: query[ANY] peacecorps.gov from 76.105.84.72
Ok I closed the port, is there anything else I should be doing? or should that fix my issue?
Your Pi-hole has likely been part of a DNS amplification attack. Bots have been sending a ton ANY
requests to your Pi-hole. The flood should stop now and no new warnings should not appear.
thanks for the help you guys, I appreciate it
