How can I restore Pi-hole's default blocklists?
#1
This command will download the default lists
sudo curl -o /etc/pihole/adlists.list https://raw.githubusercontent.com/pi-hole/pi-hole/master/adlists.default
Remove existing cached lists:
sudo rm /etc/pihole/list.*
then run pihole -g to apply the changes.
Reset to Default
Pi-hole 4.0 - whitelist not working
#2
Sure? I think ‘/etc/pihole/adlists.list’ is the correct file.
#3
Thanks mod! Nice catch. I fixed it.
#4
No longer exists :frowning:
#5
See this update:
