I'm hoping someone can help a very new Pi-hole user!
I have Pi-hole setup on a raspberry Zero and it is working very well, I am more than pleased with the performance.
However, I seem to have the classic problem of not having hostnames being resolved. I have set up conditional forwarding as per the advice in Pi-hole and found on this forum, with no success.
Most likley I'm making a rookie error somewhere, I just can't see it!
Many thanks in advance for any help.
hostnames resolved
raspberry pi zero running FTL5.2
router (Deco M9) is set as my DHCP server
Pi-hole set as DNS server in my router
router is connected to my ISP provided router (I know - probably not best practice!)
hostnames are not being resolved, only IPs showing
I find that reserving all the IPs for regular network clients (my router is th DHCP server) makes it easier to manage my network. The same mapping to client names is in all my Pi-holes.
I've added some of my reserved IPs via the Local DNS Records tab and all is working well, names are now being shown in the dashboard and Tools>Network.
That looks like the only way I'm going to get it to work for the moment.
