Good evening,
I am running into an issue where I can't seem to get it to allow YouTube and videos on Plex to play on my local computer.
I white listed:
I am using the following lists:
- https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
- http://mirror1.malwaredomains.com/files/justdomains
- http://sysctl.org/cameleon/hosts
- https://zeustracker.abuse.ch/blocklist.php?download=domainblocklist
- https://s3.amazonaws.com/lists.disconnect.me/simple_tracking.txt
- https://s3.amazonaws.com/lists.disconnect.me/simple_ad.txt
- https://hosts-file.net/ad_servers.txt
Quidsup's tracker list https://raw.githubusercontent.com/quidsup/notrack/master/trackers.txt
I believe that's it.
I have tried used DNSthingy to assist me in figuring out what to white list for Plex. I also can't seem to figure out what I would need to white list for Plex to work. I see that plex.tv is one domain along with what appears to be a hash value with plex.direct being the suffix. White listing this value did not appear to allow content to be viewed.
Both YouTube and Plex appear to work via app.
Also an oddity is that I can't seem to play media from my network share using VLC while pi-hole is running. This may coincidental, however I've tried using VLC to play content on the network share with pi-hole on and off (with reboots in between) and consistently I am unable to play content when pi-hole is enabled.
I have tried to look at the pihole.log to figure out what I should white list but there is a lot of information that I'm not sure where to start with.
Any assistance would be appreciated! Thank you in advance!
