hello. I am using this docker-compose which allows me access to the pihole admin console via traefik reverse proxy. but what I typically find is if the computer restarts or docker does, I then get DNS resolution unavailable messages in the docker pihole logs....any ideas?
SERVERIP = docker host IP = 10.0.0.189
pihole:
container_name: pihole
domainname: docker
hostname: pihole
image: pihole/pihole:latest
ports:
- '53:53/tcp'
- '53:53/udp'
# - '67:67/udp'
- 'XXXX:80'
- 'YYYY:443'
restart: unless-stopped
volumes:
- ${USERDIR}/docker/pihole/pihole:/etc/pihole
# - ${USERDIR}/docker/pihole/pihole.log:/var/log/pihole.log
- ${USERDIR}/docker/pihole/dnsmasq.d:/etc/dnsmasq.d
cap_add:
- NET_ADMIN
environment:
- ServerIP=${SERVER_IP}
- PROXY_LOCATION=pihole
- VIRTUAL_HOST=pihole.${DOMAINNAME}
- VIRTUAL_PORT=80
- TZ=${TZ}
- WEBPASSWORD=PIHOLEWEBPASSWORD
- DNS1=127.0.0.1
- DNS2=1.1.1.1
labels:
- "traefik.enable=true"
- "traefik.backend=pihole"
- "traefik.port=80"
- "traefik.frontend.rule=HostRegexp:pihole.${DOMAINNAME},{catchall:.*}"
- "traefik.frontend.priority=1"
- traefik.frontend.headers.SSLRedirect=true
- traefik.frontend.headers.STSSeconds=315360000
- traefik.frontend.headers.browserXSSFilter=true
- traefik.frontend.headers.contentTypeNosniff=true
- traefik.frontend.headers.forceSTSHeader=true
- traefik.frontend.headers.SSLHost=${DOMAINNAME}
- traefik.frontend.headers.STSIncludeSubdomains=true
- traefik.frontend.headers.STSPreload=true
- traefik.frontend.headers.frameDeny=true
