https://tricorder.pi-hole.net/q6WSs3YM/
Hello, I am running pi-hole on docker on my windows 10 box. Only over the past few days the DNS resolutions seem to cut intermittently in and out. Everything works just fine if I don't run my dns through pi-hole. Any help will be greatly appreciated.
Edit: I fixed the issue, it was Docker Desktop 4.19 that's the problem. Downgrade to 4.18 or try your luck with 4.20 and above.
