My netgear router is set to use 10.0.1.22 as it's primary DNS server, so I was under the impression that without having to manually set all devices on my network to point to the pihole ip address, the router would do that for me? Is this not the case?
C:\WINDOWS\system32>netsh interface ipv6 show dnsservers
Configuration for interface "Ethernet"
DNS servers configured through DHCP: 2002:a00:2:0:2a80:88ff:fe37:d317
Register with which suffix: Primary only
Configuration for interface "WiFi"
DNS servers configured through DHCP: fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Configuration for interface "Local Area Connection* 10"
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Configuration for interface "Local Area Connection* 11"
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Configuration for interface "Bluetooth Network Connection"
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Configuration for interface "Loopback Pseudo-Interface 1"
Statically Configured DNS Servers: fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
My apologies, I did forget the -x parameter so I will re-post new outputs below.
When copying the commands yesterday, I did copy exactly as you posted without the space; however I am unable to @ when posting in here as a new member as I receive a message saying new users are not allowed to mention other users so I have had to amend the copied output to include a space, otherwise I was unable to post a reply.
ragetti@ubuntu-vm:~$ dig @ 10.0.1.1 Woodrow
; <<>> DiG 9.16.1-Ubuntu <<>> @ 10.0.1.1 Woodrow
; (1 server found)
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 43209
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
;Woodrow. IN A
;; AUTHORITY SECTION:
. 86400 IN SOA a.root-servers.net. nstld.verisign-grs.com. 2020072900 1800 900 604800 86400
;; Query time: 23 msec
;; SERVER: 10.0.1.1#53(10.0.1.1)
;; WHEN: Wed Jul 29 09:57:11 UTC 2020
;; MSG SIZE rcvd: 111
ragetti@ubuntu-vm:~$ dig @ 10.0.1.1 -x 10.0.1.30
; <<>> DiG 9.16.1-Ubuntu <<>> @ 10.0.1.1 -x 10.0.1.30
; (1 server found)
;; ->>HEADER<<- opcode: QUERY, status: REFUSED, id: 52715
;; flags: qr rd ra ad; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0
;30.1.0.10.in-addr.arpa. IN PTR
;; Query time: 0 msec
;; WHEN: Wed Jul 29 09:58:52 UTC 2020
;; MSG SIZE rcvd: 40
