Help - question about logrotate and systemd-resolved
Update question about Logrotate and systemd-resolved
Hi all,
Quick question about logrotate and systemd-resolved.
When updating to the newest FTL I got the attached information. PiHole seems to work but o was curious if this is something I would need to fix and if anyone had any info how to do it? Thanks a lot!
youre fine. those lines are just status checks during the FTL install.
systemd-resolved is not enabled is what you want for pi-hole. installer checked and left it alone.
logrotate file is outdated. Not updating means it saw a local logrotate config that doesnt match the package one, so it skipped overwriting yours. common after an older install or a manual edit. only chase it if /var/log/pihole/ is growing without bound. otherwise leave it.
dns resolution is available at the end means the restart worked.
The logrotate message has no real meaning on the current release.
I wrote an incomplete comparison check and it will currently always report as outdated, no matter if it actually is or not.
The comparison has been fixed with send USR2 after logrotate (v7 Prep) by darkexplosiveqwx · Pull Request #6672 · pi-hole/pi-hole · GitHub, which has already been merged to development. The fix will be included with the v7 release and may be included in the next point release for core.
Incredible. Thanks both for the confirmation and info!
