Pihole should be returning DNS entry from Internet to Pihole.
Current setup: Internet<-->pihole(Docker)<-->opnsense(VM)<-->client(ubuntu running docker)
This is working to an extent, the reply is being returned correctly but then a further query occurs and appends the internal domain to the entry.
Jun 14 11:55:52 dnsmasq[7255]: query[A] registry-1.docker.io from 172.20.0.1
Jun 14 11:55:52 dnsmasq[7255]: forwarded registry-1.docker.io to 8.8.4.4
Jun 14 11:55:52 dnsmasq[7255]: query[AAAA] registry-1.docker.io from 172.20.0.1
Jun 14 11:55:52 dnsmasq[7255]: reply registry-1.docker.io is 34.233.151.211
Jun 14 11:55:52 dnsmasq[7255]: reply registry-1.docker.io is 34.232.31.24
Jun 14 11:55:52 dnsmasq[7255]: reply registry-1.docker.io is 34.199.77.19
Jun 14 11:55:52 dnsmasq[7255]: reply registry-1.docker.io is 34.201.236.93
Jun 14 11:55:52 dnsmasq[7255]: reply registry-1.docker.io is 34.206.236.31
Jun 14 11:55:52 dnsmasq[7255]: reply registry-1.docker.io is 34.201.196.144
Jun 14 11:55:52 dnsmasq[7255]: reply registry-1.docker.io is 34.228.211.243
Jun 14 11:55:52 dnsmasq[7255]: reply registry-1.docker.io is 34.199.40.84
Jun 14 11:55:52 dnsmasq[7255]: reply registry-1.docker.io is NODATA-IPv6
Jun 14 11:55:54 dnsmasq[7255]: query[A] pi.hole from 127.0.0.1
Jun 14 11:55:54 dnsmasq[7255]: /etc/pihole/local.list pi.hole is 192.168.0.30
Jun 14 11:55:57 dnsmasq[7255]: query[A] registry-1.docker.io from 172.20.0.1
Jun 14 11:55:57 dnsmasq[7255]: cached registry-1.docker.io is 34.199.40.84
Jun 14 11:55:57 dnsmasq[7255]: cached registry-1.docker.io is 34.228.211.243
Jun 14 11:55:57 dnsmasq[7255]: cached registry-1.docker.io is 34.201.196.144
Jun 14 11:55:57 dnsmasq[7255]: cached registry-1.docker.io is 34.206.236.31
Jun 14 11:55:57 dnsmasq[7255]: cached registry-1.docker.io is 34.201.236.93
Jun 14 11:55:57 dnsmasq[7255]: cached registry-1.docker.io is 34.199.77.19
Jun 14 11:55:57 dnsmasq[7255]: cached registry-1.docker.io is 34.232.31.24
Jun 14 11:55:57 dnsmasq[7255]: cached registry-1.docker.io is 34.233.151.211
Jun 14 11:55:57 dnsmasq[7255]: query[AAAA] registry-1.docker.io from 172.20.0.1
Jun 14 11:55:57 dnsmasq[7255]: cached registry-1.docker.io is NODATA-IPv6
Jun 14 11:56:02 dnsmasq[7255]: query[A] registry-1.docker.io.home.lab from 172.20.0.1
Jun 14 11:56:02 dnsmasq[7255]: forwarded registry-1.docker.io.home.lab to 8.8.4.4
Jun 14 11:56:02 dnsmasq[7255]: query[AAAA] registry-1.docker.io.home.lab from 172.20.0.1
Jun 14 11:56:03 dnsmasq[7255]: reply registry-1.docker.io.home.lab is NXDOMAIN
Jun 14 11:56:03 dnsmasq[7255]: reply registry-1.docker.io.home.lab is NODATA-IPv6
Jun 14 11:56:07 dnsmasq[7255]: query[A] registry-1.docker.io.home.lab from 172.20.0.1
Jun 14 11:56:07 dnsmasq[7255]: cached registry-1.docker.io.home.lab is NXDOMAIN
Jun 14 11:56:07 dnsmasq[7255]: query[AAAA] registry-1.docker.io.home.lab from 172.20.0.1
Jun 14 11:56:07 dnsmasq[7255]: cached registry-1.docker.io.home.lab is NODATA-IPv6
Your debug token is: https://tricorder.pi-hole.net/dpa3cgpnsw
