Headless Pi-hole automated installer text not showing
#1
Connected via terminal on OSX.
Written directions during automated install process visible.
Instructional text and options not showing, “” visible at bottom.
Pi-hole not installed yet, so no token.
Searched for similar previous threads, but didn’t find any or I’m not searching for the right keyword…
#2
Could you post a screenshot of what you are experiencing ?
#3
Here’s what I’m looking at at the moment:
#4
What OS are you installing this on ?
Try setting locale to en_US.UTF-8 and re-run the setup.
#5
Raspbian stretch lite.
Reset preferences for terminal to default. Trying again.
#6
Working now.
Bonehead errors are the best, because they are easy to fix…
Hope this helps someone at a later time.
Thanks. :slight_smile:
#7
Was it the terminal preferences reset that cleared the error or setting the locale?
#8
Ah, sorry. Resetting terminal preferences did the trick.
