instead of lighttpd
-operating system: Raspbian Release 10
-hardware: Raspberry Pi Zero W
Fresh install of Pihole on Pi Zero W but after the setup and first reboot, Pihole doesn't work. Admin shows Lost connection to API. Status is DNS service not running and FTL offline.
In the router, I changed DNS to Pihole's, restarted router, logged in to Pihole but same problem. Once I enable Pihole from he Admin panel, a page refresh disables it again.
On running Pihole restartdns, I get "Job for pihole-FTL.service failed because the control process exited with error code.
See "system to status pihole-FTL.service" and "journalctl -xe" for details
I'm fairly new to Pihole and Pi in general with basic Linux knowledge. Any help would be fine
